Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: I wouldn't make money at $1000 each...
    Registered justgary's Avatar
    Mar 2008
    All -
    I told Randy I would post pictures...
    My recent BSOD episodes nearly drove me crazy as I tried to complete these, but even without the problems I could never sell these for their actual value. I knew I was doing them for free when I started, but the time I spent on them was surprising. Since it was purely a labor of love, cost was no object, right? The frustrating thing is that I'm sure they'll get pocketed quickly and never seen again. Hopefully, I'm wrong.
    They are Geocoins, which are tokens used for Geocaching. The idea is that each coin has a specific mission that participants should help fulfill. Our local Boy Scout Council is encouraging scouts to create and search for caches as a part of the 100th anniversary of scouting in America.
    Each coin is cut from 1.5" bronze propeller shaft and faced to 0.150" thick. I reeded the shaft first on the lathe by mounting the tool sideways and feeding it toward the head stock (with the motor off), then indexing 6 degrees and doing it again (and again, and again). The rims on the top and bottom of each coin are 0.020" deep, and the lettering is 0.010" wide by 0.010" deep.
    The front (obverse) sides are roughed with a .125" and then 0.025" endmills, and finished with a 0.010" mill (all using a router-HSS). Finally, the inside corners on the BSA logo are squared up with a 30 degree engraving point starting a few thousandths deep (using Rest milling in SprutCAM).
    The back (reverse) sides are pocketed with a .125" mill and then lettered with the 0.010" mill. Finally, I inked the lettering before I sprayed them with clear lacquer. All told, it's about three hours of machine time per side per coin plus nearly two hours of cleanup, inking, and spraying each.
    Regards,
    - Just Gary
    Attached Thumbnails Attached Thumbnails I wouldn't make money at 00 each...-s7300436.jpg   I wouldn't make money at 00 each...-s7300442.jpg   I wouldn't make money at 00 each...-s7300443.jpg
    Jul 2004
    They look great!
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Registered zephyr9900's Avatar
    Feb 2006
    Those geocoins are awesome, Just Gary! Very impressive work. So the "BSA 2010" is flush with the surface of the coin and the panel recessed around them? What handwork did you need to do other than the (I assume) sanding toolmarks off the flat surfaces?
    Randy
    Jun 2004
    Those are excellent!
    Mar 2008
    Thanks, guys.
    The "BSA 2010" is recessed about 0.006" from the rim (the original surface) of the coins.
    Sanding and Scotchbrite were pretty much all the prep, and I didn't bother to get *all* of the tool marks. Some of them are worse than others. I inked the blue ones with layout fluid and then Scotchbrited them again, and the red one is done with a Sharpie. The red doesn't show up as well, but I wanted it different and didn't have red layout fluid.
    I had to work most of the ink back out with alcohol, Q-Tips, and paper towel to keep it from running out when I sprayed the lacquer. I had to strip a few of them and start over because of that. Even then, I had to spray very lightly and let it dry until I built up a protective layer. I had to strip a few of them and start over because of the runout problem.
    I was surprised that it took almost two hours each just for the hand work and spraying, but at over three hours per side on the mill, it's not like I had them stacking up waiting on me.
    The fellow I delivered them to put them on a scanner and got much better pictures than I did. You can see where I removed too much ink from the bottom of the fleur-de-lis in the first zero.
    Since they are bronze and a decent size, they have a really good feel in the hand...
    Regards,
    - Just Gary
    P.S. I didn't show you the one where the first side came out great, but when I flipped it over and started with the .125 pocket, things went bad. I watched the mill start in the center with a ramp, then start interpolating circles. I had just gotten to the door when I heard the spindle (a router motor) bog down. By the time I ran back to stop it, the mill had pulled far enough out of the collet that it was cutting through the full .150" coin. I used a wrench on the .125 mill after that. Finger tight is plenty on the small stuff. That sixth coin is now my pocket souvenir.
    Attached Thumbnails Attached Thumbnails I wouldn't make money at 00 each...-geocoin_choctaw_obverse.jpg   I wouldn't make money at 00 each...-geocoin_choctaw_reverse.jpg
    Mar 2008
    Here's the one that got away...
    Most of what look like tool marks in the scan are actually lissajous patterns made by the scanner sampling pixels at a rate different from the actual tool marks. The fly cutter gave me a really nice surface to work with, and the .125 mill at 15000 RPM and only 20% stepover (to control side loading on the router) left a nice surface also.
    I had hit the first side with scotchbrite to check it before I took it out of the vice, so some of the tool marks are gone. The stains on the back are a reaction between the bronze, the aluminum soft jaws, and the coolant.
    Hand-tightening the collet had worked just fine several times before this one, but as soon as you figure that you have it all down to a process, Murphy comes calling.
    I should finish the back anyway, and then make the hole look more like a bullet went through...
    Regards,
    - Just Gary
    P.S. One more thing I didn't mention before. The main reason I reeded the edges was so I had a decent mark to use to index the two sides. I have a line engraved on the top of the vice jaws, centered on the shallow circular pocket in the jaws (a la Randy). Marking one "reed" with a Sharpie allowed me to easily place the coin properly when I flipped it over.
    Attached Thumbnails Attached Thumbnails I wouldn't make money at 00 each...-geocoin_bad_obverse.jpg   I wouldn't make money at 00 each...-geocoin_bad_reverse.jpg
    Feb 2010
    Wow, amazing work and a great thing to do for the Scouts!
    Feb 2006
    Just Gary, thanks for the extra description, and putting up the pic of the "one that got away". It oddly reminds me of Lt. Dixon's gold coin from the Hunley...
    And I'll echo ATRepair's sentiment that you are going above and beyond for the Scouts. They are fortunate to have you as a resource.
    But I think that you were thinking of Moire pattern in describing the spatial beat frequency between the scanlines and tool marks.
    smart-a$$ Randy
    Mar 2008
    s-a Randy -
    The Hunley is an interesting story. Of course, I'd be glad to trade my bronze trinket for Lt. Dixon's gold coin.
    Thanks for pointing out my brain f@rt in identifying the pattern. I'm Moire embarrassed than you can imagine. Even after attaching the link I never even made the connection, and had wondered why Wikipedia didn't have a better description of it, Moire or less. I must have been Moire tired than I thought. I pledge to be Moire careful in the future!
    Regards,
    - b-f Just Gary
    P.S. One Moire of these jokes and I'll gag, but at this point I'm Moire afraid of reading your reply.
    Feb 2006
    Oh, I know when to sit back and just let you run with it...
    Randy
    Registered neilw20's Avatar
    Jun 2007
    Talking Howmany per minute?
    Use your CNC to make the tolls for a press like this.
    Then it will be coins per hour instead of hours per coin.
    You could also make the positive on the end of copper bar and use that to spark eroded the dies, even with grooves on the side.
    Just a thought, or make almost finished coins and engrave the last bit on them.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Mar 2008
    neilw20 -
    All of those things are true, but I really only needed one each of the five different coins. Also, I had the bronze rod, but not 1.5" tool steel to make dies.
    Randy told me about seeing a drop hammer in action making coins, and that would have been a lot of fun, but even more work to get right. Had I needed more than one of each, I would have given it a try.
    Besides, I learned a lot. Mostly, I learned how to not produce parts in high volume...
    Regards,
    - Just Gary
    P.S. I would have *really* liked to have gold plated them!
  • Page 1 of 2 12 LastLast
    1. Any money in this?
      By ottathom in forum CNCzone Club House
      Last Post: 02-10-2010, 11:12 PM
    2. Build Thread- make money from engraving?
      By denbruno_09 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-26-2008, 08:58 AM
    3. Make your money work for you (no, not spam)
      By BitBreaker in forum CNCzone Club House
      Last Post: 09-03-2007, 11:16 PM
    4. how to Make money (cnc)
      By bdrmachine in forum General Metalwork Discussion
      Last Post: 01-06-2007, 12:35 PM
    5. Need money Help
      By cnc2k in forum DIY CNC Router Table Machines
      Last Post: 11-22-2004, 01:38 PM
