Does anyone know if there is a max length for the TTS shank? I found a good deal on a 3/4" straight shank face mill arbor, but the shank length is 2" long. Will it work? I was going to pick up the TTS conversion washer from littlemachineshop.com
FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
I don't think it's a problem. I've used tool with more than 2inch long shank with no problem. And If it's too long, you can cut it.
http://www.flickr.com/photos/3264835...7623364480686/
