Results 1 to 4 of 4
Thread: problem using cutter comp
    Mar 2008
    I was running my tormach trying to use cutter comp g41 to turn on cutter compensation , in the tool offset page I select my tool in the dia column I subtract -.00x. After all this it still will not use the g41-what am I missing?
    Jul 2009
    eg;
    M6T1
    H1D1Z0
    X2.G41G1F30.
    Mar 2003
    Shelby Twp, MI....USA
    Need to see your code. Not sure what you're saying about the tool offset page either. Wear offsets don't have any effect on comp in current versions of Mach3, but will in the yet to be released version 4.
    Mar 2008
    I will post the code later on this evening, I am posting out of mastercam x with a standard fanuc post
  1. Cutter Comp.
    By Bob Z1 in forum SmartCAM
    Last Post: 05-28-2009, 11:21 AM
  2. Need Help!- cutter comp help please!
    By metlcutr55 in forum G-Code Programing
    Last Post: 02-25-2009, 08:50 AM
  3. Mycenter cutter comp problem
    By Dualkit in forum G-Code Programing
    Last Post: 02-01-2009, 03:00 PM
  4. Cutter Comp Problem
    By mgb1974 in forum G-Code Programing
    Last Post: 06-18-2008, 08:07 PM
  5. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-05-2008, 07:30 PM
