Results 1 to 9 of 9
Thread: Any Tormachs in the Palm Springs area?
    Sep 2007
    I'm thinking about a CNC mill and am looking at the Tormach, looks like Syil and Novakon have too many problems for me. I want something that is ready to run right out of the box. I'm looking for some feedback and opinions. Thanks, Ron
    Moderator tobyaxis's Avatar
    Jan 2006
    Most likely
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jun 2006
    Stavanger, Norway
    Value for money, works fine, support is great. What more is there to say.
    Read through this forum from the first thread and then come back with any outstanding questions.
    The Tormach web site does jazz things up a bit but basically what you see on the site is what you get, there are no porkies.
    Phil
    Quote Originally Posted by ranchak View Post
    Nov 2008
    Smile PCNC
    If you are looking for a reliable turnkey CNC system with high precision for all metals and the machining parts are smaller less than 12" X 8" X 6", there is system developed by ACT (Advanced Control Tech) in Los Angeles, California area. Please check WWW.ACTmachines.com for details
    Registered zephyr9900's Avatar
    Feb 2006
    Peter, if you are promoting the ACT as a Tormach alternative, you would earn some credibility by duplicating any of the demo videos from the Tormach site. A 3/4" steel plate is finished on both sides. One side is a surface cut, the second side has 0.2" removed using 1.5" diameter face mill with high positive angle inserts. would be a good place to start. Thank you.
    Randy
    Nov 2008
    Desktop CNC Mill, ACT DMC-III
    Quote Originally Posted by zephyr9900 View Post
    Randy
    It is a good idea to have some actual cutting video. ACT DMC-III is not a machine to replace the Tormach. ACT DMC-III is a high precision (repeatable 0.0002") for all metals, very compact weight only 260 lb. It is movable by 2 person without using forklift and suitable for smaller precision parts.
    Registered Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    Speaking of the Palm Springs Area and since this thread is diverging from the Tormach topic: I was out at Desert Hot Springs this evening taking in the finest waters in the world. Two aquifers from the Little San Bernardino Mountains supply the hot and cold water there. I am sure if the Romans were at DHS they would have built a shrine to Aquae Sulis as they did in Bath.
    Took this sunset picture:
    http://i72.photobucket.com/albums/i1...DHS-Sunset.jpg
    Also saw this fellow: "All right, Mr. De Mille. I'm ready for my close-up BEEP BEEP."
    http://i72.photobucket.com/albums/i1...Roadrunner.jpg
    BTW air temp ~98* F
    Don
    Have we diverged enough to go back to discussing the Tormach?
    Jun 2006
    Stavanger, Norway
    Interesting,
    Some would consider the need for a forklift to move a machine as a plus and only 260 lbs as a negative.
    Phil
    Quote Originally Posted by PeterACT View Post
    Feb 2006
    I think that someone coming here on Tormach turf and promoting their machine is inviting a direct comparison of their machine to Tormach.
    Is that actual machining repeatability or just no-load positioning repeatability? Is that unidirectional or bidirectional (i.e. going to a given point from different directions)? Peter, your machine looks like many other benchtop gantries--Isel, for one, has been making them for years and I used to own an Isel gantry which had preloaded anti-backlash ballscrews and linear bearings. It would easily repeat positioning, but actual machining involves machine, spindle and cutter stiffness.
    The ACT patent (novel method of mounting a laser pointer to the head) is a non-issue for precision machining--as has been shown many times here on CNCZone, a laser pointer has nowhere near the accuracy needed (certainly not to 0.0002"!), and serves only as a gross estimate of position. That discounted, your machine appears as just another "me too". You should start your own thread in the "Benchtop Machines" area and explain what you have to offer, in concrete terms.
    Randy
    1. Gas Springs on Knee
      By thosj in forum Bridgeport and Hardinge Mills
      Last Post: 03-23-2009, 09:25 AM
    2. Looking for Mentor Altamonte Springs, FL
      By JayL in forum Mentors & Apprentice Locator
      Last Post: 02-22-2009, 10:17 PM
    3. valve springs
      By Hiredgun in forum I.C. Engines
      Last Post: 10-14-2008, 05:39 AM
    4. Gas Springs on X3 - your ideas...
      By Ninhil in forum Benchtop Machines
      Last Post: 05-21-2007, 02:00 PM
    5. Springs
      By CNCMike in forum Solidworks
      Last Post: 03-20-2007, 12:25 PM
