Results 1 to 6 of 6
Thread: Tormach PCNC
    Jan 2009
    Cool Tormach PCNC
    M05--Will not stop spindle from coasting to a stop. Machine is 3 months old. Any suggestions?
    Banned
    Mar 2008
    There is No Spindle brake in the Tormach so don't expect it to stop on a dime...you may need to adjust your deceleration rate on the VFD...read your manual
    Jan 2009
    Thanks for the comeback. I would appreciate if you could tell me where I adjust the deceleration rate at. I cannot find anything in my manual. Thanks again.
    Banned
    Mar 2008
    http://www.tormach.com/document_libr...alibration.pdf
    http://www.tormach.com/document_libr...gnAnalysis.pdf
    you most likely have the series 2...the first link is for the series 1 machine you may need to call Tormach for more info.
    I have a series 1 machine so I can't help you much here
    Sep 2008
    If you have the series II here is a link for the "Getting Started" and "Advanced User" manuals for the Commander SK drive.
    http://www.controltechniques.com/CTc...downloads.aspx
    Registered justgary's Avatar
    Mar 2008
    om -
    Assuming you have a Series II machine, your manual (Table 5.3 on page 9-51) tells how to read the spindle drive "trips" on the spindle controller's display. Page 9-52 tells how to use the "M" button on the controller.
    Since the controller simply dumps current into a braking resistor to stop the motor, then the resistor is possibly blown or disconnected. In that case, the controller will show "tr-OU" on the display.
    Regards,
    - Just Gary
    1. BobCad Cam post for Tormach PCNC
      By brooklynmetal in forum Tormach Personal CNC Mill
      Last Post: 09-08-2007, 07:42 PM
    2. TORMACH CNC PCNC 1100 only $6800.00 ???
      By twocik in forum Benchtop Machines
      Last Post: 08-21-2007, 03:26 PM
    3. Engraving on The Tormach PCNC
      By phil burman in forum Benchtop Machines
      Last Post: 09-15-2006, 09:45 PM
    4. Any Interest in a Tormach PCNC Forum?
      By dkaustin in forum Suggestions for the CNCzone.com site.
      Last Post: 07-29-2006, 10:21 PM
