Results 1 to 3 of 3
Thread: lathe help
    Jan 2009
    lathe help
    We recently purchased a pcnc and are loving it! Unfortunately, we have a very limited budget and cannot afford the duality lathe. I was wondering if anyone has tried putting a regular bench-top lathe on the bed of their tormach. We actually already own a bench-top lathe that looks exactly the same as the duality lathe except there isn't a sensor for the rotation speed. I guess we would be fine to start out with out needing the sensor, but it would be cool to cut threads and stuff, which would need the sensor. Has anyone figured out how to make their own and has anyone been successful using a non-duality lathe on their tormach?
    Mar 2007
    I would start with CNC4pc.com Arturo can probably help you out. The C3 indexer can be adapted to fit the input on the front of the Tormach. That's about as far as I can take you.
    Registered neilw20's Avatar
    Jun 2007
    CNC Lathe/Mill
    I put the job in the chuck.
    Mount some tool holders and drills sticking up off the table.
    Great CNC latch for small parts, as long as you don't need a live center.
    Y axis makes tool height adjustment trivial.
    For threads I hold the job in a chuck/4th axis on the table and threadmill.
    Threadmilling does not require any sync signal.
    Use a bit of imagination.
    With my rotating head I can actually put the spindle horizontal so it looks like a lathe.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  1. Converting my Engine Lathe to an 8-Station Turret Lathe!
    By widgitmaster in forum General Metal Working Machines
    Last Post: 10-31-2011, 04:27 AM
  2. Need Help!- Lathe spindle speed and lathe facilities
    By GuntisK in forum TurboCNC
    Last Post: 10-26-2008, 06:22 PM
  3. New Machine Build- My CNC mill with mini lathe performing CNC lathe operations
    By ryansuperbee in forum General Metal Working Machines
    Last Post: 08-20-2008, 02:06 AM
  4. Anyone have a mini cnc lathe or medium sized cnc lathe
    By nymachinist in forum Mini Lathe
    Last Post: 01-23-2006, 09:36 PM
