Page 1 of 4 1234 LastLast
Results 1 to 12 of 46
Thread: Automatic Tool Changer
    Mar 2008
    How difficult would it be to equip a Tormach with an automatic tool changer? I did a search on the internet and found this one that says it’s designed to work with the Tormach tooling system:
    http://littlemachineshop.com/product...ProductID=2937
    Has anyone here tried it or heard any feedback about it?
    Jan 2008
    I haven't seen or heard of anyone with this tool changer on a tormach. I have watched their video which shows the changer working on a small benchtop mill. It appears to be a well thought out device. I wonder if they have macros or add-ins for Mach-3. I don't want to run two computers and they don't seem to offer the device as a add-on to the computer system that runs your Tormach now. There are too many questions about this device for me to get interested in yet. They don't directly say it will work with our Tormachs that I could read on their website. Do they have pictures of the device on a Tormach? Maybe you could talk them into letting you review it for all of us who own and use PCNC 1100's.
    I hope this device does develope into a useful option we can use. They should produce a video of it mounted on a Tormach.
    HAve Fun
    Steve
    May 2006
    china
    Could not open the link from China.
    Jan 2008
    Tool Changer practicality
    Quote Originally Posted by Rockwall View Post
    Here's the thinking that I went through. I have to think of this from a business standpoint, hobbyists have to deal with different economics...namely the house ways and means committee, [insert wife's name here].
    Let's assume that the system can, indeed, be installed on a Tormach with a few custom brackets, etc. Further, let's assume that Mach can interface with it successfully and that you don't need a separate computer to operate it. Two very big "If's".
    System cost: $1,499 (Sale price)
    Rough cost to install system on a Tormach (IMHO): $500
    Cost to modify all your tool holders (assume 24): $229.75
    Total cost = $2,228.75
    Now, from the point where the Tormach comes to a stop at the tool change position, it currently takes us about 20 seconds to change a tool. It can be done faster of course, but we don't do this 24/7 around here.
    Using the tool changer video and a stop watch, I see that this system can do it in 12 seconds. So, the time saved per tool change is 8 seconds.
    Now let's assume that you're spending at least $25/hr for the machine (gotta pay it off sometime!) and the operator's wages combined. Very conservative, IMHO.
    The tool changer then saves me about $.06 per tool change. That's 37,129 tool changes to break even! At about 4 tool changes per part...that's 9,282 parts machined!
    Bottom line...No doubt, the "cool factor" is very high, but for our business it's a VERY bad investment.
    That's my ridiculously long 2 cents!
    Jun 2006
    Stavanger, Norway
    I think the point of the tool changer is your operator doesn't need to be in constant attendance, or even be paying attention as to when the next tool change is due. So the diffential cost is in the "no need to hover".
    I have my reservations for other reasons. If you are going to leave it unattended, which is the whole point of an ATC ,it had better be 100% reliable or the potential damage could render the purchase price irrelevant.
    Phil
    Quote Originally Posted by TimTheToolMan View Post
    Jan 2008
    Quote Originally Posted by philbur View Post
    Phil
    Phil,
    I'll have to admit, I hadn't considered that perspective. However, the only cnc machine that can be left safely unattended in our shop is our cnc driller. This is probably why I hadn't thought of that angle.
    Given that someone is always attending, then, I would also argue that an atc gives me nothing in the way of increased capabilities...regardless of the cost. I can think of a lot of more beneficial places to spend $2200...4th axis, probes, etc. that would expand our capabilities.
    Thanks for the other perspective, though.
    Tim
    Mar 2005
    Personally I would love an ATC. I run allot of smaller parts made with 0.125 and smaller tooling. These parts can run without supervision and with an ATC I could design parts that used more tools or had longer cycle times as well as run these parts throughout the night. This would let me run the larger part that need supervision during the evening/day.
    Jan 2007
    I'm going to be building an ATC. I'm just going to do it similar to how Hoss did his. Why spend the money on a fancy gizmo that swings tools out of the way when you can have the mill pick the tools up from the end of the table. I have some extra space to burn on my table as the longest parts are only 10" long.
    Wade
    Jan 2008
    Hoss?
    Okay I'll bite Who is Hoss and where can I see his design. I have my ideas for one but it would be column mounted. I need my table space for the fourth axis I use a lot. I've worked on so many over the years I think it would be a good feature for the same reasons you quoted. Long runs of small intricate parts.
    Have fun and please let me know where to see Hoss's design.
    Jan 2007
    Here's his website and the link to the ATC project:
    http://www.hossmachine.info/projects_7.html
    If i'm ambitious enough, I have an idea for an ATC that is automated, but for now, the one like Hoss made should be enough for my immediate needs.
    Wade
    Wade
    Jun 2006
    Stavanger, Norway
    You could mount the "Hoss" design above the rotary table or you could mount the tools in a single row at the front or back of the table.
    I also think this design is a good starting point. Its reliability will be high because of its simplicity, there are effectively no moving parts. The speed of the change will be slower than a manual change so the only benefit is if you are able to leave the machine unattended.
    I know nothing about commercial ATCs but it would seem to me that some built in fail-safe features would be a good idea. You need to look at the consequence of a tool change not happening as intended. A starting point with respect to protection might be in the form of a micro switch for each tool station in order to confirm that all the tools that should be in the ATC are and that the tool that should be in the spindle is not still in the ATC.
    Also if the machine is incorrectly positioned when replacing a tool it would try to push the ATC through the table, not good. So A micro switch on the limit of travel for the spring loaded tool rack could also provide a signal to stop the machine.
    Just some thoughts.
    Phil
    Quote Originally Posted by stedgar View Post
    Jan 2007
    I think the biggest failsafe is that the operator needs to make 100% sure that he has homed the machine before doing any tool changes. A limit or stop switch on the tool rack is definitely something I'm planning to incorporate myself. Just to be safe. Dang, Looks like I'm going to need to get myself another parallel port to support an ATC and a power drawbar and a few limit switches.
    I'm not too concerned with the speed as that is adjustable in the macro file.
    Wade
  • Page 1 of 4 1234 LastLast
    1. I wish I had an Automatic Tool Changer...
      By Chris64 in forum General Metal Working Machines
      Last Post: 09-09-2007, 08:59 PM
    2. Automatic Tool Changer
      By spalm in forum DIY CNC Router Table Machines
      Last Post: 07-10-2007, 08:49 PM
    3. Automatic Tool Changer
      By Chivo in forum Mechanical Calculations/Engineering Design
      Last Post: 03-19-2007, 07:57 PM
    4. R8 automatic tool changer
      By N4NV in forum Bridgeport and Hardinge Mills
      Last Post: 03-05-2007, 09:44 PM
    5. Automatic tool changer
      By bunalmis in forum Mechanical Calculations/Engineering Design
      Last Post: 02-04-2006, 04:57 PM
