Hi TT350
Well other than swapping out the Stepper Drives for Servo units, you would likely need to also install a Belt Drive between your Servo Motors and the Ball Screws? Most of the Servo installations I have seen (non Tormach) are DC Brushed Servos with a Belt Drive reduction. This could depend on the type of Servo Motor you plan to use. The higher end machines that are using Brushless A/C Motors tend to be direct drive. The Power Supply would also likely need replacing to match the voltage of your new Servo Motors? Hope this has been some help.
Willy
LinkBack URL
About LinkBacks
