Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: Another Tormach mill delivered
    Jun 2006
    My mill and deluxe stand showed up today and are sitting in their crates in the garage. I've got a week of vacation to check it out and move it to the basement, so there should be some "fun" in my near future.
    The mill was ordered at the beginning of August and arrived at the warehouse around the middle of September. Delivery to my home was delayed to today at my request to coincide with the vacation. The delivery guy was very professional and got the whole thing off-loaded in about 15 minutes with no problem, though his lift gate was just barely large enough to accomodate the crate footprint. An inch or two the wrong way would have had it on my driveway .
    Mike
    Jan 2004
    ontario canada
    I just got mine too, waiting to get it onto stand.
    How are you going to do the rigging?
    Jun 2006
    That's still up in the air, so to speak.
    The move into a basement complicates things somewhat. The immediate need is to get it off the pallet in the garage and powered up so some alignment checks can be run before disassembling it for the move to the basement. I'm about to find if an engine hoist is up to that task.
    I haven't decided on how much disassembly will be required to get the mill into the basement and will probably use a couple of rails and and an A-frame mounted electric winch to lower the heavy parts down the stairs as that method worked well for a 400-500 lb surface grinder base a year or so back. I can point you to pictures of the A-frame & winch if you are interested.
    In the basement, I'll probably rig a 2-ton chain hoist to the ceiling joists so that the mill can be lifted onto the Tormach base and will probably need to rent or buy a pallet jack to get the mill and stand into position. Getting the pallet jack down the stairs should be fun too.
    BTW, the Yahoo Tormach group has a few pictures of someone else's basement move.
    Mike
    Apr 2005
    us
    Congrads, both of you guys on getting your new Tormachs, and I wish you well during the move of those heavy pups!!!
    Like when you build a house, all of your friends disapear until your house is built ( or your 1150 lb. milled is moved and on it's stand).
    Did you guys buy the Tormach stands or are you building them.
    Be careful
    Ron
    Jun 2006
    Stavanger, Norway
    Congratulations on the new arrival.
    I also used a chain hoist (1 ton) attached to a ceiling joist to lift the mill onto my homemade stand, which has removable wheels. I would have bought a trolley jack but for the fact it would only get used once and I don't really have anywhere to store it. I designed the stand so that I can easily use an existing automotive trolley jack to fit and remove the wheels, one side at a time. I already had the wheels assemblies made up for moving my lathe around, so it was a no cost option.
    With a normal ceiling height (ca. 2.4m in this neck of the woods) there's not alot of headroom to spare, so if you are buying lifting equipment specific for the job its worth doing some measuring and planning before you buy. I only just made it.
    Regards
    Phil
    Quote Originally Posted by MichaelHenry View Post
    Mike
    Jun 2006
    Ron,
    I bought the Tormach deluxe stand since time is short and I don't have any welding experience.
    Mike
    Jun 2006
    Quote Originally Posted by philbur View Post
    I've got around 87" (2.2 m) to play with, maybe a bit more if I can squeeze a hoist mounting beam between two joists. Should be a "fun" project.
    Mike
    Jan 2004
    ontario canada
    I went with the tormach stand after reading one of the other posts suggesting that it was very well made and a good value for the price.
    I am very pleased with the fit and finish of the base.
    I am going to go the route of a small fork lift truck, and set it up in the garage.
    I had one rigging quote of $800 for what will be a 30 min job max, so even with the rental costs of equipment i will be $500 ahead of the game.
    i couldn't even concieve of getting it into my basement i have only one staircase and its spiral!
    Jun 2006
    Stavanger, Norway
    Hi Mike,
    My 1 ton hoist had a minimum length of 300mm, hook to hook, and the lifting eye on the machine was 1900mm when sitting on the satnd. You also have to allow for the strops and the fact that they stretch when you lift. Also it is not easy to get the mill to lift exactly square.
    Good Luck
    Phil
    Mike
    Jun 2006
    A fork lift would be nice, but it would be a thrilling ride down the stairs <g>.
    Phil - sounds like I might have a problem with clearance in the basement. Time will tell.
    Mike
    Feb 2006
    us
    Wheres the pics? Love pics?
    Jun 2006
    Zip,
    I've been taking pictures as I go and hope to have them along with a narrative up on a web site by the end of the week.
    In the meantime, here's a pic of the mill and pallet up on blocks so that an engine hoist can be used to lift it.
    The setup is just to test clearance of the hoist extensions under the pallet - I'll use a sling for the real thing.
    Mike
    Attached Thumbnails Attached Thumbnails Another Tormach mill delivered-millblockedonpalletforlift.jpg
  • Page 1 of 2 12 LastLast
