Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: TTS compatible tooling for 2-3" deep pocketing ops?
    Aug 2006
    UK
    Hi guys, I need to make some largish aluminium parts with 2-3" deep pockets, and I'm looking for some TTS compatible way of hogging out their innards.
    I currently have very long 100mm (4") 10/12mm end mills in TTS set-screw holders, but ideally I'd like something stiffer.
    Does anyone know of a TTS compatible tool that would do the job at a reasonable price?
    The Tormach modular insert stuff looks like it might work - but I can't tell from the data sheet what the diameter the shafts on the holders are. They'd need to be smaller than the heads to allow deep work. It's also rather expensive IHMO - and I can't seem to find any reviews of them on here.
    Cheers.
    Sep 2009
    Tooling
    You might take a look at the Glacern EM90-750B with APGT1135 inserts. It's not exactly what you were looking for, but a TTS ring added to the 3/4 shaft gets one a "TTS compatible", and it's one piece. The shaft is about twice the circular area of a 12mm tool (that is, twice as stiff). Can mill to 3" depth. I've got one, like it. My only problem with it is that it's another bloody insert to stock.
    I've looked at the TTS thread-on cutters. Seem to be Mitsubishi sourced, and as you note, expensive unless used for production.
    Registered Steve Seebold's Avatar
    Mar 2009
    San Clemente, CA
    First off, there is no way I would try to mill a pocket 2 to 3 inches deep. I would create a hole pattern and drill most of the stock out then use your end mill or whatever cutter you choose to finish the sides and bottom.
    Depending on the size of the pocket you need to make, it could take hours to make it that deep with an end mill, but you could drill it out on minutes.
    If you want to use a 3/4 inch end mill, fine, use a drill to make a 3/4 inch hole, then use your 3/4 inch end mill and make .200 stepovers to plunge ruff and you'll move more material than you ever would by side cutting with an end mill.
    I know it works, I have several repeat jobs that I do this way. One particular job takes 36 minutes to side cut with an end mill, and it takes 11 minutes to plunge ruff and finish, and I do it all with the same cutter.
    You can buy good parts or you can buy cheap parts, but you can't buy good cheap parts.
    Aug 2006
    UK
    Quote Originally Posted by GLCarlson View Post
    Thanks - the Glacern mill looks interesting, but by the time you've bough a box of inserts, you're out $250 odd...
    How does the TTS conversion collar work on a tool with a parallel shaft and no obvious step to glue it to? What stops the drawbar force breaking the glue?
    Aug 2006
    UK
    Quote Originally Posted by Steve Seebold View Post
    That is a good point - it would be very slow side milling away 5kg/10lbs of metal...
    Have you got any video of your pluge milling in action? I've never seen it done on a relatively lightweight machine.
    Mar 2009
    San Clemente, CA
    Quote Originally Posted by digits View Post
    I don't have a video right now, but I have a repeat job that requires plunge ruffing that I will be running in the next 2 to 3 weeks. I'll get some video then and post it.
    For the job I am going to plunge ruff, I use a 1/2 inch 2 flute end mill with a .060 radius at 4,500 RPM. When I do the slotting cuts (full width of the end mill) I use a .150 stepover and a 25 IPM feed rate, then when I get out of the slot I increase the stepover to .225 and the feed rate to between 30 and 40 IPM. Trust me, it fills up the chip bucket in a hurry.
    I make my program so I leave .015 to .020 stock for the finish cut.
    Try it and you'll never side mill a pocket again. I also use this method when I have a lot of material to remove from the outside of a part.
    Sep 2009
    Tooling
    Re cost. It is indeed the thick side of 3 bills. I got mill and inserts on sale, probably wouldn't have done it otherwise.
    Next let me agree with Steve S. Drilling and/or plunge roughing is the way to do this.
    That said, my approach to the TTS is to make shrinkfit collars out of 4140 HT when I have a compatible shaft. Someone else reported using 7075 Al in an earlier thread. I don't have a PDB (yet), so I'm hand tightening-haven't seen a problem. Don't have any experience with the actual Tormach product, and should have made that clear. My excuse is that it was early, and I was insufficiently caffeinated while typing.
    Registered Scott_M's Avatar
    Apr 2006
    Medina , Ohio USA
    +1 for the TTS Modular Tooling
    That is exactly the type of machining operation the modular tooling was designed for. You get a very rigid extension with the option of changing the heads. I am not sure what info you saw but they do have a good pdf with specs. It can be found here. http://www.tormach.com/uploads/51/DS...0212A-pdf.html The diameters of the shank on the M8 is .565" and the M10 is .725" The dimensions for the cutter heads are in the pdf.
    It is a nice elegant solution for your problem.
    Scott
    www.sdmfabricating.com
    Jul 2004
    I purchased the Tormach 17mm center cutting insert EM and am super impressed with the metal it removes.
    You can search my name for a post I made on it with a video.
    Mar 2009
    San Clemente, CA
    Here is a short animated video from Sandvik to show what I am talking about to plunge ruff your pocket.
    http://www.sandvik.coromant.com/en-u...s/default.aspx
    Jul 2004
    Steve, it seems that I have trouble doing plunging with EMs, as the machine shudders unless I go very slow. I have less of an issue using drill bits, but I normally use a deep drilling cycle at any depth. Maybe a chip clearing problem?
    With that said, I haven't done much if any partial width plunges, so that may be part of the issue.
    Not sure if it's my technique, or something with my machine.
    I have not tried center cutting with the new insert em I purchased from Tormach, that may work better.
    Any tips would be appreciated.
    David
    Mar 2009
    San Clemente, CA
    Quote Originally Posted by David Bord View Post
    David
    If you're plunging into a part, I would do it with 2 tools. First use a G83 cycle to drill a hole so your end mill has a place to go, then change to your end mill. An even faster way would me to use a large drill and use a large enough step over so the drill doesn't break through into the previous hole.
    If you'd like, send me a .dxf file of your part, the pocket depth, and the corner you're starting from, and I'll send you a program that will work the way I would do it. Don't forget to tell me what size end mill you will be using and whether it's HSS or carbide.
  • Page 1 of 2 12 LastLast
    1. looking for feedback on deep pocketing
      By kalld in forum Machinist Feedback
      Last Post: 09-21-2011, 08:36 PM
    2. Need Help!- Machining 1" wide x 2-1/4" deep slot
      By midguard in forum General Metal Working Machines
      Last Post: 02-15-2011, 06:15 PM
    3. Replies: 2
      Last Post: 08-09-2010, 11:17 AM
    4. Replies: 3
      Last Post: 01-06-2010, 05:32 PM
    5. Deep Pocketing Aluminum
      By John H in forum General Metalwork Discussion
      Last Post: 11-28-2006, 09:15 PM
