The PDB has a bendable cable tray that protrudes above the head. I don't know if it exceeds 84" in most-squashed-mode, but its possible.
Couple questions:
1. The 1100 spec sheet shows height of 81 3/4" (770 73") with stand I only have 84" to the ceiling. So looks like it will fit but would I need extra room for cover removal or maintenance?
2 Does the power drawbar add extra height to the unit(s), if so how much? This will be on my "must have" list.
So basically would I be able to use and or repair unit with only 2 1/4" clearance on the 1100?
My CNC build: http://www.cnczone.com/forums/genera...ml#post1059321
C-Constant
N-Nonworking
C-Contraption
Here's a thread where I asked a similar question. Don Clement's answer and the associated image will tell you everything you need to know.
http://www.cnczone.com/forums/tormac...questions.html
Frederic
[URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
Vertical Lathe tool holders and more.
Thanks guys.
Still need to know if PDB extends above original measurement. I do have the ability to position mill between the concrete I beams (guessing 20" between) and that would gain me another 7".
While I'm asking...what are your thoughts on the stand? $1650 seems like alot for a stand and would still need to be enclosed.
Although I may need to build my own stand anyway for clearance.
I'm still planing the Ann Arbor show to see it in person.
C-Constant
N-Nonworking
C-Contraption
C-Constant
N-Nonworking
C-Contraption
I think you're right. Watched bunch of videos today and stand looks really nice.
Plus I'm in the middle of a conversion now,YES it's fun but I'm really ready to just make some parts plus conversions are tough to do when machine(s) are apart. I'm done with the $1500 hobby machines using $10 end mills it's time to jump in with the big boys.
I believe the Tormach will last me a lifetime and be a good investment. (wife doesn't think so)
Man this CNC hobby just grabs your soul and sucks you in.
3 yrs ago I would have told you $20,000 machine is just for professionals. But all I knew then was manual and when I worked as machinists (way back when) CNC was a myth we heard about at NASA!
I know some of you remember those days if your shop had 3 Bridgeports and couple Warner & Swasey turret lathes you were king of the hill.
NO conversion this time around.![]()
C-Constant
N-Nonworking
C-Contraption
What Steve S. said: Just do it.
I built a stand from Tormach's instructions. Spent days on it, significant bucks, trying to be frugal. Dumb decision. Lasted a couple months. Never did get rid of the leaks. Got the deluxe stand. Worth every penny.
BTW- an enclosure, using 8020 rails and surplus lexan, will add about three hundred bucks if you shop around. Also worth it.
C-Constant
N-Nonworking
C-Contraption
