Results 1 to 4 of 4
Thread: Aligning Kress high speed spindle attachment
    May 2012
    I am roughing out an aluminum part with normal spindle, and want to use the high speed kress spindle to finish the surface of a mold.
    The lowest speed on the kress spindle is too fast for a wiggler. What are some good methods to get the alignment of the kress spindle and tool proper to my roughed out work peace.
    Mar 2006
    Make a hole in the work piece with the Kress and find the center of the hole with the main spindle and note the offsets on the controller's DRO
    Odo
    May 2012
    Thanks. I was thinking of milling a corner with the Kress and doing the same thing measuring the corner with the wiggler. I like the hole idea as well.
    I need to remove the Kress for roughing, and remount for the finish work. Do you think it will keep the same/close enough offset after remounting it against the backstop plate?
    Mar 2006
    That depends on the repeatability you need. I suggest you mill the corner or make the hole, measure offsets, remove and replace the Kress, make a new hole and check offset to determine if repeatability is acceptable. Do as many times as needed until you learn the repeatable range. BTW if making the hole with the Kress is the last roughing operation I don't see why you need to remove it after measuring offsets.
    Odo
  1. Build Thread- High speed attachment for X4+
    By PEU in forum Syil Products
    Last Post: 04-26-2009, 05:40 AM
  2. High Speed Spindle Attachment
    By yoopertool in forum Hard and High Speed Machining
    Last Post: 06-20-2007, 07:26 AM
  3. high speed attachment
    By tc2007 in forum General Metal Working Machines
    Last Post: 03-16-2007, 07:06 PM
  4. High speed grinding attachment
    By devincox in forum I.C. Engines
    Last Post: 10-02-2006, 04:42 PM
  5. Pinnacle XJ-95 & X2 High Speed Spindle Attachment
    By KDN Tool in forum Product and Manufacturer Announcements
    Last Post: 07-17-2006, 02:28 PM
