You're right Don, you saved a bunch over GibbsCam, but when I bought it, in 1999, I was doing 4 and 5 axis work, turning and multitask machining. As well as up to 7 axis turning and wire
EDM.
I'm not sure if SprutCam has those capabilities. At least not now.
I bought it because I had reached a point in the company where I was working there no further room for me to advance and I was getting burned out just running machines. The company had their own product and it was just run the same parts over and over again.
When I had my shop, I almost never took a job that was more than 25 pieces. In face, my business card said "one to ten pieces is our specialty".
I can see my part in GibbsCam before I machine it as well. I can see it in either solid block form or in finished part form. Either way, I know what the cutter's going to do before I post the program.
With Sprutcam, can you post your program, set your tools, pick up your edges, load your program, press the green button and walk away from the machine knowing that your program is right and you'll come back to a good part? I can do that with Gibbs.
Don't get me wrong. I'm not saying Sprutcam is not a good program, but I had Gibbs when I bought my machine and as long as it still works, I see no reason to change.
