Results 1 to 8 of 8
Thread: My First Part
    Dec 2007
    UK
    My First Part
    Hi guys
    Thought I would share my first real part on my very new 1100
    Keep in mind that I am a very noob at maching - but a bit of a wizz at computers (that's my day job)
    It's a door catch for the delux stand - the front door as supplied was a bit out of spec and the catch did not engage with the frame.
    So I thought - what a good first real part
    The process is
    1. Draw it up in SolidWorks 2012 - that took 10mins 'cos I have already climbed that learning curve
    2. do the CAM in Sprut - that took 2 days 'cos still in the foothills of that learning curve
    3. cut metal!!!!
    Attached are some pics
    the solidworks dump is the part in solidworks
    then some machining in some scrap - actually from a computer case - 3mm steel of some sort.
    (a) is the first attempt - not too good - clamped the whole 18" length at the ends and it was bouncing - learnt about clamping from that
    (b) oops - got the feeds and speeds from GWizz and did it with no coolant - doing it step by step wanted to do a simple part first to see if all worked and then put on the delux stand drip trays and link up the coolant.
    within 1" the whole thing got cherry red and chips welding themselves to the cutter (1/4" HSS 4 flute center cutter) - quick bang on the EStop and reach for the extinguisher just in case. - learnt about coolant from that.
    (c) Got it all together and did it - the top is as finished the bottom has been separated and the tabs cleaned up - and the door now closes :}
    Peter
    Attached Thumbnails Attached Thumbnails My First Part-first_part_sw.jpg   My First Part-first_part.jpg
    Jan 2007
    Nice job! I remember how hard it can be to take those first steps. keep it up!
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Aug 2010
    Congrats on your first part! It's all gravy from now on...................okay, not really, but it will still be fun. :P
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    Good job. Wait until you have the mill on the stand with everything working. You'll have even more fun!
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Jan 2012
    Hey, congrats, man. Nice first step!
    I always run with water coolant, but today when doing a couple of light passes I left the coolant of. On a whim I grabbed a couple of chips out of the air. Quickly turned the coolant back on after feeling how hot they get!
    Registered nitewatchman's Avatar
    Oct 2011
    Birmingham, Alabama
    Quote Originally Posted by tbaker2500 View Post
    Doesn't take very long to inspect a hot horseshoe!
    nitewatchman
    Jan 2012
    Congrats on the first part, looks good!
    My first parts were wood, I have just graduated to aluminum, this machine and related software will keep you busy for years to come!!
    mike sr
    Dec 2007
    UK
    Hi Mike
    Well....
    It's not *really* the first part - cut air first (can't show that one )
    and then cut MDF - serveral times
    Good job I did too - as at that point I did not understand the crucial need to set the right tool number in Mach to get the right z offset
    so the center drill plunged straight into the MDF - bag on the EStop - no harm done though.
    As you say this is going to be years of fun !!!
    Peter
    1. Newb ? - CAD Part interference & mating part dims
      By pabmartin in forum Mechanical Calculations/Engineering Design
      Last Post: 11-06-2009, 01:18 AM
    2. sheetmetal part? flatten a rolled part?
      By Rich05 in forum Solidworks
      Last Post: 08-12-2009, 11:22 PM
    3. Verify Cut part to Design part.
      By CaseyCAM in forum NCPlot G-Code editor / backplotter
      Last Post: 11-01-2008, 10:22 PM
    4. Newbie- Part holding and milling 3D part on 2.5D Mill?
      By john_t_h in forum General Metalwork Discussion
      Last Post: 03-15-2008, 07:35 AM
    5. Missing steps on just a certain part of the part
      By ZipSnipe in forum Stepper Motors and Drives
      Last Post: 01-02-2008, 02:40 PM
