Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: Configuring Tormach drivers for a Keling motor.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    I'm sure that the first thing you're asking is "Why?"
    I have a plan and I need a sanity check.
    I have a Tormach 1100, Series 2, with an 8" fourth axis. My table carries two Glacern vices which are parallel and coplanar. That's not a quick and easy setup, and I like to leave them in place whenever possible. But when I need to use the fourth axis, one of them has to come off.
    The fourth axis and the vices are quite heavy and a pain to move.
    But I have a very nice Sherline 4th axis with a Keling KL23H2100-35-4B attached and wired up. A lot of my 4th axis work is less than two inches in diameter, with very light machining loads. So the Sherline might be up to the task. With a few modifications to the Sherline's base, I could set it up so it can be clamped in one of the vises.
    It looks like the following DIP switch settings will give me 3.2 amps and 10 microsteps.
    1 On
    2 Off
    3 On
    4 On
    5 Off
    6 On
    7 On
    8 Off
    Can anyone think of a flaw in this plan?
    And, does anyone know where I can get another of the green connector blocks that plugs the stepper motor wires into the driver? I'll need a spare if I want to do quick switch overs between the two configurations.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Sep 2009
    I replaced my 4th axis motor with a Keling one so its not a big deal. I would get the black round plug that goes into the side of the machine instead of the green one at the driver.
    Aug 2009
    Austin, TX
    Quote Originally Posted by compunerdy View Post
    I thought about that. The reason to swap at the driver is to remind me to reconfigure the DIP switches.
    The Keling motor is best set at 3.2 amps, and the Tormach motor uses 2.7. There's a risk of frying the Tormach motor.
    For the initial test, I'm going to try the Keling motor with the Tormach's configuration. The motor is oversized for the rotary table, so it may work just fine at 2.7 amps. If that's the case, then I will follow your suggestion.
    I'm going to wait until tomorrow to try it out. I want to bounce this idea off of one of Tormach's engineers before I try anything.
    Frederic
    Mar 2008
    Frederic:
    "Can anyone think of a flaw in this plan?"
    The Keling model number that you provided is actually for a motor rated at
    3.5 amps rather than the 3.2 amps that you stated. A more serious problem
    is that the Sherline rotary table has a 72:1 worm drive ratio rather than the
    more common 90:1 that the Tormach rotary table has. This means that the
    angular calibration setting in the Mach 3 setup will also have to be changed
    every time that you switch between those two rotary tables.
    There are other alternatives available, some requiring more work than others.
    I have my home made 8" rotary table mounted at the extreme end of the mill
    table so that I very rarely have to move it (only for workpieces that are very
    long, and this has never happen yet). You might want to consider mounting
    the Tormach rotary table somewhat beyond the end of the T-slots using an
    extension plate to provide sufficient room for non-rotary table work. Such a
    plate would be quite trivial to make and if you use a tail stock it would also
    need to be adjusted upwards by the thickness of the plate to keep the two
    centers aligned.
    Aug 2009
    Austin, TX
    Quote Originally Posted by Zetopan View Post
    Frederic:
    Two good points.
    I chose 3.2 amps because the Tormach driver doesn't have a setting for 3.5 amps. 3.2 is the closest option.
    The worm ratio is pretty easy to deal with. I've cloned the Mach configuration, and can edit the clone to work with the Sherline table.
    Frederic
    Aug 2009
    Austin, TX
    Results!
    I gave it a try today. It works, and was easier than I thought it would be.
    First I connected the motor and set the driver to 3.2 amps. That worked just fine.
    Then I powered down and set the driver back to the Tormach setting of 2.7 amps. The motor still worked.
    So I'm just going to get another Amphenol connector for the Sherline table's cable, and I'll be in business.
    I'll be sure to post back if I let the smoke out of anything. Hopefully this will be the end of this thread.
    Frederic
    Sep 2009
    Glad to hear it all worked out for you. I have a 6 inch rotary and thought of getting a smaller one as well since everything I do is 2" OD or under.
    Aug 2009
    Austin, TX
    I did some testing today. Now I have monogrammed shot glasses.
    http://www.youtube.com/watch?v=HOiBB3xEphk]Engraving a shot glass on a Tormach. - YouTube
    Jan 2012
    Heh. Fun.
    Mar 2012
    united states
    Sweet.
    Oct 2008
    TXFred,
    That’s awesome
    Kevin
    Jan 2012
    TXFred, what kind of tool is that in the video? I imagine a diamond tipped bit, but did you make the sprung holder?
  • Page 1 of 2 12 LastLast
    1. Need help setting up drivers, etc. (Keling + Mach3)
      By BrooksMachining in forum Benchtop Machines
      Last Post: 11-12-2009, 05:25 AM
    2. 3 NEW KELING-4030 MICROSTEP DRIVERS
      By heilcnc in forum EBAY ADS
      Last Post: 10-01-2009, 09:33 PM
    3. 3 NEW KELING-4030 MICROSTEP DRIVERS
      Last Post: 09-28-2009, 07:54 PM
    4. Keling Inc. KL-8056 Drivers
      By heathmanc in forum Automation Technology Products
      Last Post: 06-19-2007, 08:54 PM
