I'm impressed. Very nice work.
Link to 2nd video
http://www.cnczone.com/forums/videos...st1097967.html
Kevin
You can buy good parts or you can buy cheap parts, but you can't buy good cheap parts.
Ya know what's really cool about this spark arrestor? NO ONE will be able to say " oh, I know someone who has one just like it".
Very nice job.
Nice work...
Can you talk a bit on how you machine the side attached to the 4th axis and how you cleanly part it off ?
David
David,
I used a 2d contour with a curve from the part on the A axis side and cut Z at .5 then rotate A axis 180 deg and run the same 2d contour with the curve reversed so I will be climb milling and run at Z .5. This leaves a tab that is 1 inch thick, Then I use a finish waterline with a finish Z depth of .5 Then copy the waterline operation and Rotate 180 deg and rerun the operation.
I keep copying the 2d contour operations and the finish waterline operations and change the Z value, I was stepping down .250 every operation until I had a tab that was .o75 thick.
I saw the tab with a hacksaw then have to blend the tab by hand.
Kevin
