Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Tormach tool holder set screws
    Jan 2012
    I know there was a post on the tormach tool holder setscrews, I tried the search without any luck.
    I have had problems with the setscrews in mine so I bought a couple new metric ones to replace them, they worked fine but were sloppy in the threads, kind of like a class 4 fit.
    Today I was checking them out again and found that a 1/4- 28 fits the small toolholder and a 3/8- 24 fits the larger one. I guess they were supposed to be inch screws instead of metric ones? The metric sizes will fit but are sloppy in the threaded holes. I checked them with a thread pitch gage and they seem to be identical between the inch and metric ones.
    I guess thats why the sloppy fit possibly so that both screws could be used?
    mike sr
    Registered zephyr9900's Avatar
    Feb 2006
    Mike, the tread is this one, in which you made the last post. As to using an M6x1 screw in a 1/4-28 hole, I won't comment...
    Randy
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    My holders all use inch threads. With good quality inch set screws, the thread isn't sloppy at all.
    If your tool holders are still sloppy after you switched to good inch hardware, it may be because the metric set screws damaged the thread.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Jan 2012
    Quote Originally Posted by zephyr9900 View Post
    Randy
    I assumed that they were metric because they are Chinese made and it takes a metric wrench, and they came with metric screws. Maybe the older ones had different set screws. (mine are only a few months old)
    Evidently my assumption was wrong. I should have called the folks at Tormach about the correct replacement screw, although the screws mike out to be metric (.236 instead of .246) on the 1/4" size.
    The M5 is similar to a 10-32, but in this case the m5 a few thou larger than the 10-32.
    mike sr
    Feb 2006
    Well, a 1/4" setscrew uses a 1/8" hex wrench (.125" nominal) and an M6 setscrew uses a 3mm hex wrench (.118" nominal) so the 3mm wrench would not be all too loose in a 1/4" setscrew socket... BTW I forgot the last in my previous reply.
    Quote Originally Posted by mike sr1
    Chinese made [snip] the screws mike out to be metric (.236 instead of .246) on the 1/4" size
    No comment there either...
    BTW all my setscrew holders date from fall 2006 and have American threads on the setscrews.
    Randy (who has never, ever, used a metric/inch hex wrench that "just about fit", no not ever... )
    Aug 2009
    Austin, TX
    Quote Originally Posted by mike sr1 View Post
    That's only because the hexagonal hole on the original set screws is as badly made and toleranced as the rest of the set screw.
    Frederic
    Jun 2005
    I have a variety of TTS holders from very old to very recent and the setscrew sizes vary rather widely between them...
    Jan 2012
    The 1/2" holder is tapped 3/8 24, the screw thread is .010 undersize that was in it and the socket wrench doesnt fit well at all.
    I was wrong in assuming they were metric, they just are not good quality setscrews as per TxFred.
    I have been to the hardware and all is good! The screws that came out were ten thousanths undersize on the 3/8" ones......
    mike sr
    Jun 2006
    Quote Originally Posted by shred View Post
    Were they all made by Tormach?
    Dec 2010
    this post made me laugh. I have always meant to check the threads to figure out what size they were since neither 1/8 not 3mm have even a decent fit even for chinese hardware.
    Jan 2012
    Quote Originally Posted by PriddyShiddy View Post
    I have a Chinese lathe and the screws in it fit like that as well, most of them I changed out and that was over 20 years ago, but its still running at least an hour or two a day. I think I replaced the drive belt once.
    mike sr
    Jun 2005
    Quote Originally Posted by MichaelHenry View Post
    All the ones in question, yes.
  • Page 1 of 2 12 LastLast
    1. Tormach TTS Tool Holder Dimensions?
      By plasmator in forum Tormach Personal CNC Mill
      Last Post: 09-03-2012, 12:08 PM
    2. Replies: 0
      Last Post: 01-30-2012, 09:50 AM
    3. Tormach tool holder specs
      By skidmarx in forum Benchtop Machines
      Last Post: 01-20-2012, 09:21 PM
    4. Need Help!- Tormach Tool Holder
      By ianober in forum SolidCam
      Last Post: 03-29-2010, 02:59 AM
    5. Need Help!- endmill holder questions? 2 screws?
      By Micro Milling in forum General Metal Working Machines
      Last Post: 02-05-2010, 04:52 PM
