Results 1 to 3 of 3
Thread: Question for those with an ATC and deluxe stand.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    I would be very grateful if somebody with an ATC would take some quick measurements for me.
    I would like to put a small shelf in the back left corner of the stand, mounted to the top of the walls. The shelf would be about at least 12" deep, and as long as I can make it. Access to the shelf isn't really an issue. It's going to be used to hold addons to the mill that will rarely need to be serviced. (Coolant aeration pump, oil skimmer, giant reservoir of way oil, etc.)
    I'm also about to order my ATC, and I want to design the shelf so that it won't interfere.
    I've attached an image to make things clearer.
    Thanks in advance!
    Frederic
    Attached Thumbnails Attached Thumbnails Question for those with an ATC and deluxe stand.-atc.jpg
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Sep 2009
    At 12" deep you can go about 31" wide.
    Aug 2009
    Austin, TX
    Thank you!
    Frederic
  1. Deluxe Stand wanted.
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 04-14-2011, 06:38 AM
  2. Deluxe stand feet question
    By dbrija in forum Tormach Personal CNC Mill
    Last Post: 01-17-2011, 06:14 PM
  3. Tormach Deluxe Stand Dimensions ?
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 01-30-2010, 03:27 PM
  4. How Do You Like The Deluxe Tormach Stand?
    By Willyb in forum Tormach Personal CNC Mill
    Last Post: 01-31-2007, 10:38 AM
  5. Coolant for Tormach with deluxe stand?
    By MichaelHenry in forum Tormach Personal CNC Mill
    Last Post: 08-20-2006, 12:49 PM
