Results 1 to 11 of 11
Thread: New, improved splash guard
    Jan 2012
    Hokay, even with my fancy-dancy shower curtain splash guard, I was still getting wet. Got sick and tired of it, so I super-sized the concept. I used 3/4" aluminum u-channel, and 3 shower curtain liners from walmart. I went up 48" above the front of the tray.
    All 3 sides are covered, and there is a split in the middle, shown in the pictures. I can easily change tools, and even get to the E-stop button. Much quicker and easier to move out of the way. It won't stop any projectiles, but it does stop ALL of the splashing, now. :-) Took about an hour of build, $40 for the u-channel and $30 for the curtains liners.
    Attached Thumbnails Attached Thumbnails New, improved splash guard-img_0001.jpg   New, improved splash guard-img_0002.jpg   New, improved splash guard-img_0003.jpg   New, improved splash guard-img_0004.jpg
    May 2011
    Carnation, WA - USA
    Quote Originally Posted by tbaker2500 View Post
    Very nice!
    Jul 2004
    Agreed, very nice...
    Sep 2010
    If you wanted something that will stop projectiles, you can add another curtain of the welded stainless mesh they use for shark-suits. A bit pricey at $35+ per square foot though. But you can see through it, and it'll stop most flying objects.
    Aug 2009
    Nicely done! I used PVC pipe and thick vinyl, but I like the sliding curtain idea better.
    Registered Steve Seebold's Avatar
    Mar 2009
    San Clemente, CA
    I like it. Can you show a picture of how you attach it to the chip pan?
    You can buy good parts or you can buy cheap parts, but you can't buy good cheap parts.
    Feb 2006
    Quote Originally Posted by Steve Seebold View Post
    I like it. Can you show a picture of how you attach it to the ship pan?
    Why attach it? I would just let it sit there. For cleaning, lift it off, and you have full access.
    Regards,
    Ray L.
    Jan 2012
    I'll take one tomorrow. I just screw it in with 2 10-24 machine screws and nuts at each corner. It's very sturdy. Yes, you want to attach it, having it loose would be a big headache. Just pull the curtain out of the way for unfettered access.
    Jan 2012
    Here's the promised pic:
    Attached Thumbnails Attached Thumbnails New, improved splash guard-img_0002.jpg
    Mar 2009
    San Clemente, CA
    Does you enclosuer cover 3 sides or all 4? I like it either way.
    I will occasionally use a cutter called a Shear Hog, and when I do, coolant goes EVERYWHERE, including all over me. Or if I have the coolant lines improperly adjusted when using any tool it can be a coolant disaster.
    This enclosure would all but eliminate that problem.
    Today is the day. I'll post pictures when it's finished.
    Last edited by Steve Seebold; 02-09-2013 at 11:24 AM. Reason: spelt som werds rong
    Jan 2012
    I started with 3, then have strung a support cable across the back and covered it, also. It's needed for larger cutters.
    1. New splash guard
      By tbaker2500 in forum Tormach Personal CNC Mill
      Last Post: 03-16-2012, 09:01 PM
    2. Custom top cover / splash guard for VF-3
      By JasonR in forum Haas Mills
      Last Post: 02-24-2012, 08:34 PM
    3. Chip and Coolant Splash Guard
      By BobWarfield in forum Industrial Hobbies (Support forum)
      Last Post: 08-01-2010, 12:04 PM
    4. Splash Guard for 8x12 Lathe
      By caleb105 in forum Mini Lathe
      Last Post: 11-13-2009, 05:17 PM
    5. Splash Guard for HF 8x12
      By jk080 in forum Mini Lathe
      Last Post: 01-12-2008, 08:01 PM
