Results 1 to 11 of 11
Thread: My new tool rack.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    My new tool rack.
    I felt like showing off my latest upgrade to the shop.
    One of my long term projects has been to make my own tool holders. This was a success, and so suddenly I had an enviable problem. Too many tool holders. This lead to a bit of a mess on my workbench.
    I'd seen a tool rack made out of a cutting board, and I thought that it was a brilliant idea. Cutting boards are cheap, and they're made of oil and solvent resistant, high temperature plastic. So yesterday I set out to copy that idea.
    $20 at the grocery store got me two of the biggest cutting boards they have. One became the top of the rack, and the other was cut up to make the supports. Here's the result.
    The bottom of the rack, showing the support structure.
    Most TTS holders will fit in the grid of holes. Some tools, such as the 1/2" drill chuck, or a 2" slitting saw, are too large. So there are six spaces dedicated for large diameter tools. All told, this rack will hold 62 tools. And it takes up the same amount of space as two Tormach tool racks, which could only hold 42 tools.
    It's meant to be put together with countersunk screws, but I was out. On Monday I'll go buy the correct hardware. But for now, the button head screws work well.
    Of course, now I'm back to my old problem. Too many holes. Not enough tool holders!
    Attached Thumbnails Attached Thumbnails My new tool rack.-tools_.jpg   My new tool rack.-rack.jpg   My new tool rack.-tools_.jpg   My new tool rack.-rack_underside.jpg
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Registered Steve Seebold's Avatar
    Mar 2009
    San Clemente, CA
    That's neat. All you need now is bench space to store it.
    You can buy good parts or you can buy cheap parts, but you can't buy good cheap parts.
    Aug 2009
    Austin, TX
    That's the eternal problem, isn't it? The workbench is never big enough. The air compressor never pumps enough CFM. And you always need 100 more square feet of floorspace.
    Registered Scott_M's Avatar
    Apr 2006
    Medina , Ohio USA
    Nice job Fred !!
    I did something similar a couple years back, but mine slides out from under my bench. No bench space taken and it does not collect chips either.
    http://www.cnczone.com/forums/tormac...rack_pics.html
    Scott
    www.sdmfabricating.com
    Mar 2009
    San Clemente, CA
    Quote Originally Posted by TXFred View Post
    Ain't that the effing truth.
    Jan 2012
    Nice!
    I'm just approaching filling all the slots.
    Wog
    Wog is offline
    Oct 2008
    Looks great! Super idea using the cutting boards.
    I'd think about getting stainless screws when you change over so that there won't be a rust problem on the black oxide steel from any coolant.
    Registered Gerry Sweetland's Avatar
    Feb 2008
    Looks nice Fred.
    Are those just standard mailing labels you have on the tool? If so, how do they hold up?
    I have a plywood tool rack with numbers on each hole and you wouldn't believe how many times I put the wrong holder/ tool # in the wrong slot as I'm working.
    Your method for labeling seems like a nice way to go.
    Red hair and black leather, my favorite color scheme...
    from Vincent Black Lightning 1952 by Richard Thompson
    Aug 2009
    Austin, TX
    Those are from a label maker, so they're printed on plastic. So far, the labels are staying in place with no problems. And will peel off cleanly when I want to relabel a tool holder.
    The problem with having a label maker and a CNC is that while the CNC is working, I spend all my time labeling things. My workbench is becoming a shrine to Obsessive Complusive Disorder.
    Frederic
    Feb 2008
    Frederic
    Ahh, OCD I have CDO. It’s like OCD, but the letters are in alphabetical order, LIKE THEY ARE SUPPOSED TO BE.
    Jul 2004
    Quote Originally Posted by Gerry Sweetland View Post
    ROTFLMAO... Damn that was funny!
    1. Haas TM Cat 40 Tool Rack
      By mecheng10 in forum Haas Mills
      Last Post: 06-06-2012, 09:45 AM
    2. Big Tool Rack ( Pics )
      By Scott_M in forum Tormach Personal CNC Mill
      Last Post: 04-03-2012, 04:30 PM
    3. Cat 40 Tool Holder Rack - Haas, Rack, or Benchtop
      By mecheng10 in forum Product and Manufacturer Announcements
      Last Post: 09-17-2011, 09:52 AM
    4. Build Thread- A custom tool rack for my C6
      By PEU in forum Syil Products
      Last Post: 03-17-2009, 12:50 AM
    5. Gang tool rack on the C6 (CAD Drawings)
      Last Post: 06-25-2008, 12:18 PM
