Results 1 to 7 of 7
Thread: Is a spindle warmup necessary?
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    I've been wondering if a spindle warmup is necessary for these spindles. I run one, because I'd rather be safe than sorry. And it gives me time to finish my morning coffee. But I was wondering if it's really necessary, or if I'm just taking life off of my spindle for no reason.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Jan 2005
    TXFred
    No it is not necessary when bearings are using grease as the lubrication,& not running over 5,000 RPM, when using oil yes you need to use a warm up program
    If you are going to start the spindle out at more than 5,000 RPM to 10,000 RPM then you would want to run a warm up program
    Mactec54
    Registered carlboe's Avatar
    Mar 2008
    Quote Originally Posted by TXFred View Post
    I've been wondering if a spindle warm up is necessary for these spindles. I run one, because I'd rather be safe than sorry. And it gives me time to finish my morning coffee. But I was wondering if it's really necessary, or if I'm just taking life off of my spindle for no reason.
    Frederic
    Frederic
    I do run 3-5 minute warm up just because I do it with the Hass machine. Just my 3 cents. I do the x-y and z to slow to fast about a feed of 60 and back down to feed of 5.
    Carl Boe
    Nov 2005
    Quote Originally Posted by carlboe View Post
    Frederic
    Carl Boe
    I agree, start the spindle and move all x, y and z for a warm up.
    Just my 2
    Jan 2007
    I started doing one because I noticed that if I didn't, my XY zero *seemed* to move after I ran my first job. From a layman's view, this made some sense because the mill could be quite cold but usually warmed up after the first program finished (not only from the mill operating, the the room would be warmer in general - body heat, compressor going, etc). So now I run a warmup program for 10 minutes.
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Mar 2012
    united states
    30 years ago working 3rd shift in a machine shop our job starting the week was to start all the machines manual and cnc. I still let my manuals warm up a little, even though I keep my shop 68-72 degrees. Also that cup of coffee to get in the zone to work, beats rushing into a job. Years ago I had a 81 cnc lathe, if it didnt get its 20 minute warm it be a pain all day. Me just out of habbit I will just give my 1100 a 5 minute warm up. Gotta have my coffee.
    Jan 2012
    I do quick parts on cold (and I do mean cold, 50-60 deg in the winter) machine for years with no problem. Never have warmed it up, never even knew to try. I do make sure it gets a healthy pump of waylube, a little extra when it's cold.
    1. warmup
      By salemereyes in forum CNCzone Club House
      Last Post: 11-07-2010, 11:55 PM
    2. looking for general warmup programs
      By rapid in forum General Metal Working Machines
      Last Post: 10-15-2009, 09:13 PM
    3. Need Help!- SPINDLE WARMUP
      By CNC_BOB in forum OKK
      Last Post: 05-01-2009, 04:32 PM
    4. VF 6 Trying to get to warmup settings
      By SpringKing in forum Haas Mills
      Last Post: 09-28-2006, 10:39 AM
