It should be 120 on each side = 240. If you have 250 on one side something is wrong.
My new Tormach 1100 came in last week and I am now trying to get it hooked up to power. I live off grid in Colorado and will be running the mill off the generator.
My generator is a Craftsman 6500 watt with a 4 prong 220 plug, however, when tested with a meter the hot on one side is 250V and the other hot is showing 120V. Is this normal or do I need to take the generator to an electrician to have a plug hard wired in for the mill?
Thank you for any help.
Ken
The computer should be run from an inverter, or you have some other way of smoothing the power.
I am in Australia, our standard voltage is 240, but quite often the voltage at the outlet is 250, which my Tormach seems to handle quite alright.
I am sure that not all supplies are exactly what they are supposed to be due to distance from the supply or transformer, length of lead in cables or whatever- I am not an electricianbut I do know that that small a variation dosen't matter, I run the Tormach controller on 240 volt setting as well.
I would ask Tormach their opinion about this first, you will get an honest and informed opinion from people who know their stuff, and if they don't know they will find out. The more I deal with Tormach the more impressed I get with them
in my opinion they are a truly awesome company to deal with. As an example I sent an email to Andy at just before 9am here this morning ( just before 5 pm there) and received an immediate reply, BTW it was only a setup query- nothing wrong.
Will
It sounds like you are off a pin.
Put one probe on neutral. One hot should read 120. Then the other hot should read 120. Put a probe in Hot 1 and the other probe in Hot 2, and it should read 240 (or thereabouts).
If you are not sure of what you are doing, I highly recommend getting someone involved who is, it can be a very expensive mistake.
If the Gen. replicates the normal N.A. 120-0-120 plus ground as mentioned you should also ensure that the 0v or mid point is set up as a neutral by bonding it to a proper Earth ground electrode or water pipe equivalent, this would be done right at the 0v source point.
Ken,
Where in rural CO are you? I am outside of Pagosa Springs. Will be ordering my 1100 later this summer.
Did you consider solar for your power? We have a son who lives off-grid in Guatemala, using only solar...powers his 220 tools just fine, though nothing as sensitive as a cnc machine.
Good luck with your new mill!
Thank you for all the help.
The problem was that I was trying to use the actual ground prong on the plug. When testing with a meter and touching the ground and one of the hot receptacles the voltage readings were way off. The fix was to use the neutral as the ground and that gave 120V to each of the hot receptacles.
Thanks again for all of your help, the machine is making chips now.
Gerry Kmack,
I am over by Fort Garland, not too far from you. We go to Wolf Creek regularly.
The house is powered by solar, and soon to be wind, but I don't have enough money to setup a separate system for the mill. The batteries are crazy expensive.
Ken
It is some weird 120/240V Generator plug. I talked with an electrician and its supposed to be correct? Also fixed an earth ground to the generator.
Ken
