Results 1 to 4 of 4
Thread: Kipware M Bad Character
    Oct 2006
    Is anyone using Kipware M? I wrote a simple facing and pocketing program with
    it, posted the code to Mach3 which all went fine, then when I hit cycle start I got the message "bad character in line 1" I don't know enough about G code (yet) to know what is wrong, I tried to copy the code into here but it didn't work?
    Will
    Got it in here !
    10000
    facing and pocket
    (PROGRAM DESCRIPTION)
    G00 G91 G28 Z0
    G28 X0 Y0
    G54
    M01
    N0001
    facing
    (TOOL DESCRIPTION)
    (OPERATION DESCRIPTION)
    G00 G91 G28 Z0
    T20M06
    G90S4000M03
    G54
    G00G90G43Z+20H20
    M08
    G54
    G00G90X-21.54Y16.46
    G00G90Z5.
    G01Z0.F300.
    G01G91Z-0.5F300.
    G01G91X20.27
    G01G91X151.27F300.
    Y33.
    X-151.27
    Y32.81
    X151.27
    G00G91Z2.54
    G90X-21.54Y16.46
    G01G91Z-2.54F1270.0
    G01G91Z-0.4
    G01G91X20.27
    G01G91X151.27F300.
    Y33.
    X-151.27
    Y32.81
    X151.27
    G00G91Z2.54
    G90X-21.54Y16.46
    Z5.
    G00 G91 G28 Z0 M09
    M01
    Feb 2006
    At least one problem I see here is you have comment text that is not enclosed in parenthesis -- see red highlight. Also you have two lines - see green highlight - that appear to be line numbers -- but none of the other lines are numbered. I would delete them.
    As to why this might be happening - I don't use Kipware but I assume you have some kind of entry for the machine you are targeting - make sure that is selected correctly.
    10000
    (facing and pocket)
    G00 G91 G28 Z0
    G28 X0 Y0
    G54
    M01
    N0001
    (facing)
    (TOOL DESCRIPTION)
    G00 G91 G28 Z0
    T20M06
    G90S4000M03
    Oct 2006
    Thanks for that Jeff, the bit about the comments came to mind while I was thinking about the problem, I also sent the code to Kipware and they told me that the + symbol shouldn't be in the code too? I just don't know how it got there, the software wrote the code I just filled in the boxes. Another thing I am not sure about,I have Kipware set to Metric and put Metric dimensions in the boxes, should I see G21 in the code somewhere?
    Will
    I won't get a chance to actually run the code for a couple of days
    Feb 2006
    Quote Originally Posted by wbleeker View Post
    Will
    I guess technically the G21 is optional assuming your machine controller is set to metric. However, good practice is to always have a have a safety block at the beginning of your gcode to set/reset your controller to a known state. A G21 would be part of that safety block. Do a search on gcode safety block and you will see there are typically 9 or 10 items in the typical safety block.
    Jeff
  1. Need Help!- character display
    By hedgehog in forum Fanuc
    Last Post: 10-24-2010, 10:39 AM
  2. Kipware Software by Kentech
    By MarkT in forum G-Code Programing
    Last Post: 08-09-2010, 12:50 PM
  3. Need Help!- What's the ASCII character(s) used for EOB?
    By PMBottas in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-25-2010, 11:12 PM
  4. character code not found
    By mikean45 in forum Fanuc
    Last Post: 02-18-2010, 11:34 PM
  5. Replies: 5
    Last Post: 12-25-2006, 04:40 AM
