Page 1 of 3 123 LastLast
Results 1 to 12 of 27
Thread: Reducing stepper motor marks
    Oct 2011
    Recently I have been making a bunch of circular parts, and noticed this odd pattern on the side walls.
    I'm pretty sure it is related to the steps from the motors. How can I reduce these marks?
    Registered Scott_M's Avatar
    Apr 2006
    Medina , Ohio USA
    A couple of questions.
    Are the marks at 12,3,6 and 9 O'clock ?
    Are your circular moves G2 & G3 or a bunch of little G1's ?
    Scott
    www.sdmfabricating.com
    Jan 2012
    That's my first thought, too, if it's outputting many small G1's you'll be seeing a complex polygon, not a true arc. What CAM software are you using, with what Post-processor?
    Oct 2011
    I'm pretty sure the move is a G3, as it has a distinct sound over a bunch of little G1's.
    Jan 2012
    Hm. I get perfect circles and arcs on my 1100. What size bit are you using and what feed rate?
    Oct 2011
    The circle is fine - these are just surface finish marks, probably less than .001 roughness.
    The bit was a 3/8 HSS 90 degree drill point end mill (45 degree side angle) running at 4k rpm and maybe 7ipm or so feed.
    Apr 2006
    Medina , Ohio USA
    I'll ask again. Is this the only mark ? Or are there 4 of them 90 degrees apart , or 2 of them 180 degrees apart ? If so it could be a mechanical issue like backlash.
    If it only appears in one place it is almost certainly in your code.
    Please let us know.
    Scott
    Oct 2011
    It's not my code. The code has one big G3 that goes all around the circle. It's not the entry point either. This particular feature is near, but not necessarily at, 45 degrees. I don't recall if there are other marks at 90 or 180 degrees to this as the piece has been sandblasted since.
    On other pieces with arcs in them, I see a similar appearance where a linear move in one axis only has a relatively nice surface finish, but once the contour starts arcing, the surface finish gets worse.
    I think this mill has about .001 of backlash.
    Here's another picture with a circular move.
    There are a few of these patterns around the circumference, but not necessarily evenly spaced.
    Apr 2006
    Medina , Ohio USA
    That looks like chatter. Does the cut make noise there ?
    If you have 2 marks at 3 and 9 o'clock it would indicate that there is backlash in X if you have 2 marks at 12 and 6 o'clock it would indicate backlash in Y. If you only have 1 mark at some other place I doubt that it is a mechanical issue.
    Scott
    Oct 2011
    No chatter at all.
    When I get chatter, I get a series of very finely spaced diagonal lines.
    The pattern in this picture appears at something like 5 oclock, and maybe another one at 4 oclock, another at 6:30, but nothing from then till 9.
    Registered Gerry Sweetland's Avatar
    Feb 2008
    Are you doing the full DOC in increments? I get marks like that when the tool comes around and does a plunge to the next depth at the same place on the tool path/ part location.
    This pocket was cut with a roughing end mill.
    Red hair and black leather, my favorite color scheme...
    from Vincent Black Lightning 1952 by Richard Thompson
    Jan 2012
    Sorry to hijack this thread, but Gerry's picture illustrates the same problem I'm having on a multi-pass pocket cut. That bump evident in his picture is there on a 1/8" EM pocket I'm doing, and it's at least 5mil off location from the rest of the pass. Which is more than the tolerance off my axis + the deflection of my carbide tool. Where does this bump come from?
  • Page 1 of 3 123 LastLast
    1. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
      By wf1318 in forum Stepper Motors and Drives
      Last Post: 07-25-2010, 03:19 AM
    2. Integrated stepper motor? with built-in stepper motor driver
      By uirobot in forum Product and Manufacturer Announcements
      Last Post: 06-07-2010, 04:59 AM
    3. Need Help!- Loosing step more and more on X axis only after reducing the accl/velocity step motor
      By Calico in forum DIY CNC Router Table Machines
      Last Post: 04-09-2010, 08:23 PM
    4. Reducing motor current requirement?
      By JerryB123 in forum Stepper Motors and Drives
      Last Post: 11-19-2007, 05:33 PM
    5. Beltdrive-stepper motor-stepper motor driver
      By Georg in forum Stepper Motors and Drives
      Last Post: 10-16-2007, 05:56 PM
