Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 27
Thread: Reducing stepper motor marks
  1. #13
    Jun 2006
    Stavanger, Norway
    I think you guys need to look into entry and exit strategies. ramp, helical, interpolate are a few key words. A direct plunge in and/or out will almost always produce the type of artifact as shown, especially on a roughing cut.
    Phil
  2. #14
    Registered Gerry Sweetland's Avatar
    Feb 2008
    Quote Originally Posted by philbur View Post
    Phil
    Thanks Phil,
    Those are certainly strategies that I need to learn and understand. I have seen those key words mentioned here frequently and am very interested in gaining knowledge on those techniques. I'll keep plugging away as it is all part of the fun figuring this puzzle out :-)
    Red hair and black leather, my favorite color scheme...
    from Vincent Black Lightning 1952 by Richard Thompson
  3. #15
    Feb 2007
    +1 Phil ! Tangent in and out
  4. #16
    Oct 2011
    My marks aren't entry/exit marks. I'm pretty sure it is stepper related due to how the spacing of the lines increases and then decreases away from the center of the pattern. Like some kind of aliasing, or whatever you call it.
  • #17
    Jun 2006
    Stavanger, Norway
    Beanbag, the neat increase and decrease in amplitude has the appearance of resonance, possibly due to the cut frequency matching the stepping frequency, or some whole multiple thereof.
    Is it just a surface finish or are there detectable steps in the part.
    Chatter patterns take many forms.
    I think to find it you are going to have to make some guesses and then devise tests to check your guesses.
    Phil
  • #18
    Oct 2011
    It really is small steps in the part from the steppers. I have tried higher and lower SFM, feeds, etc and similar marks are always there.
    The most recent case of this was when I was doing an interpolated inner diameter circle in a plastic part. I got the entry and exit moves as an arc coming in, so there is no discontinuous change in x or y. No matter the speed or feed, I always got little marks on the surface. I was able to alleviate the problem somewhat by using a bigger end mill, because the arc of the end mill's diameter more closely matched the circle.
  • #19
    Registered Steve Seebold's Avatar
    Mar 2009
    San Clemente, CA
    Phil
    Another thing to try is a spring pass. I always use spring passes if I want to not have start and stop marks. On my finish pass, I will also circle in, and circle out. Sometines I'll use 2 or 3 spring passes. I have also learned that if I get vertical marks around the outside or inside of a part, I will increase the feed rate to smooth out the steppers.
    You can buy good parts or you can buy cheap parts, but you can't buy good cheap parts.
  • #20
    Jun 2006
    Stavanger, Norway
    Why are you sure it is stepper marks. A full step is only 0.001" and a microstep is only 0.0001".
    Phil
    Quote Originally Posted by beanbag View Post
  • #21
    Oct 2011
    Phil
    Could be "resonance marks". I get what you are saying that if it is steps only they should be very finely spaced. This would still count as "marks due to stepping motion, which I am trying to reduce". Marks are still there even at different speeds and feeds.
    Basically the machine buzzes too dam much.
  • #22
    Jun 2006
    Stavanger, Norway
    But if they are stepper marks only then they should appear symmetrical about the 3, 6, 9, and 12:00 o'clock positions.
    My proposal is that they may be a result of resonance caused by a combination of a number of potential sources that may or may not include stepper movement. Cutter vibration/flexing/chatter, axis backlash, lack of spindle preload , climb or conventional milling are some that come to mind, as well as of course, stepper frequency.
    I guess many of us have seen similar marks from time to time. A finish pass often reduces it to an acceptable level.
    Phil
    What other kind of surface feature would change in frequency as you go around a curve or circle?
  • #23
    Oct 2011
    I edited my post just as you were posting. But if you go back to the very first picture, the marks or aliasing occur at the same angle of the circle, so to speak, even though I am milling out a conical section. Thus the marks occur at a particular "slope" of x/y, so it must be resonating with some step frequency. When I have some free time, I will do more testing as you suggested.
  • #24
    Jun 2006
    Stavanger, Norway
    Do you have the new 3 phase steppers or the original 2 phase. The original steppers/drive have a documented resonance at around the 10 ipm mark.
    Phil
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
      By wf1318 in forum Stepper Motors and Drives
      Last Post: 07-25-2010, 03:19 AM
    2. Integrated stepper motor? with built-in stepper motor driver
      By uirobot in forum Product and Manufacturer Announcements
      Last Post: 06-07-2010, 04:59 AM
    3. Need Help!- Loosing step more and more on X axis only after reducing the accl/velocity step motor
      By Calico in forum DIY CNC Router Table Machines
      Last Post: 04-09-2010, 08:23 PM
    4. Reducing motor current requirement?
      By JerryB123 in forum Stepper Motors and Drives
      Last Post: 11-19-2007, 05:33 PM
    5. Beltdrive-stepper motor-stepper motor driver
      By Georg in forum Stepper Motors and Drives
      Last Post: 10-16-2007, 05:56 PM
