Page 1 of 3 123 LastLast
Results 1 to 12 of 34
Thread: My new 1100
    Jan 2012
    My new 1100
    I guess I should have ordered a pair of white gloves, everywhere I touch the machine it leaves smudges, so much for the cream color ha!
    I also need a stop button pendant so that when I hit the cycle start and something isnt right in the program, I can stop it without having to look up and locate the stop button, instantaneous shut down is what I am looking for. I think i will do some checking around to see if something of that nature is available.
    So far I am well pleased with the machine.
    mike sr
    Jun 2006
    Stavanger, Norway
    This one worked out OK for me:
    vistaCNC
    Phil
    Registered Scott_M's Avatar
    Apr 2006
    Medina , Ohio USA
    www.sdmfabricating.com
    Jan 2012
    Oh don't worry, soon the smudges will be obscured by the grease smear, metal chips and wood dust. :-)
    Glad you're having fun.
    Jan 2012
    I am just running the wizards trying to get used to the machine, and cutting wood, it is softer than steel and if theres a screw up, I would rather it plunge into a piece of pine........ Anyway the 2x4 cutoffs are getting scarce around here, but I do have a surplus of sawdust ha!
    mike sr
    Sep 2007
    Good to hear mike , how are you making out with the programs ?
    Jan 2012
    Quote Originally Posted by carlacab View Post
    I havent done much with it Carl, I have a buddy that knows cad very well, so he is coming over one evening next week and maybe he can give me a few pointers.
    I wanted to get familiar with the machine first, from what I have seen on the software, its a bit complicated for me, I think I may have done better with a cheaper package but who knows.
    I got another order of pipes in so I wont be able to play with it much for a couple of days.
    mike sr
    Dec 2007
    Congratulations on your purchase. I'm planning on getting mine in a month and I just cant wait. I want an external estop switch too, but $105 seems a little unreasonable for what appears to be no more than $25 worth of parts.
    Jan 2012
    I have noticed a vibration at the upper speeds in high and low range at approx 90 percent Has anyone else noticed this? I have narrowed it down to the belt not being balanced, not a big problem just somewhat annoying.
    The machine controller computer also loses selective usb ports at times, I have had certian x or y directions not work on the mouse but will on the pendant, also it loses it from the keyboard occasionally. I have had this with other (laptop) computers, just wondering if its common?
    mike sr
    Registered nitewatchman's Avatar
    Oct 2011
    Birmingham, Alabama
    Mike,
    I had the same vibration problem at higher spindle speeds particularly at maximum RPM's and it also appeared to me that it was the belt fluttering.
    When I have had this problem on other machines I have switched to a Fenner Link Belt to ease the problem. After a bit of a search I found a 3/8" wide Link Belt and applied it to my 1100 and the problem was largely solved. At 4500RPM there is no vibration in the belt at all. I first started using these a long time ago and now use Link Belts on most of my equipment.
    This may work for you.
    nitewatchman
    Jun 2006
    Stavanger, Norway
    If you are using MACH you shouldn't be using a laptop.
    Phil
    Quote Originally Posted by mike sr1 View Post
    Jan 2012
    Quote Originally Posted by philbur View Post
    Phil
    I probably wasnt clear enough, this happens on the tormach computer that came with the machine, I have had this situation happen on a laptop before with the usb cordless mouse. It would lose the mouse so I would pull the receiver out of the usb socket and reinsert it and it would work fine again. I was just wondering if this is similar to that problem? It really doesnt hurt anything, just that I cant get movement on all three axis on say the keyboard or the mouse sometimes, the pendant has always worked fine.
    mike sr
  • Page 1 of 3 123 LastLast
    1. 770rpm's on the 1100?
      By howecnc in forum Tormach Personal CNC Mill
      Last Post: 08-30-2011, 06:27 PM
    2. 1100 on its way!
      By dbrija in forum Tormach Personal CNC Mill
      Last Post: 02-18-2011, 08:12 AM
    3. 1100 on it's way
      By Etced in forum Tormach Personal CNC Mill
      Last Post: 01-03-2011, 03:52 PM
    4. Who wants the 10,000 rpm spindle for the 1100
      By pzzamakr1980 in forum Tormach Personal CNC Mill
      Last Post: 03-05-2010, 01:11 PM
    5. For those of you with a PCNC 1100
      By HLF Ordnance in forum Tormach Personal CNC Mill
      Last Post: 01-01-2010, 06:51 PM
