Page 1 of 4 1234 LastLast
Results 1 to 12 of 43
Thread: auxiliary spindle recommendations?
    Registered 300sniper's Avatar
    Jul 2007
    i'm getting tired of engraving at 4500 rpm. i want to get an auxiliary spindle setup for engraving. i'm assuming spindle runout and endplay would be the most critical things when choosing one with rpm being the next important.
    i use 1/4" half round conical engraving bits and i'm usually working with 416 stainless, if any of that matters.
    does anyone have any recommendations for this? the kress kit tormach offers is a bit more than i want to spend and i'm capable of making my own mount.
    Registered zephyr9900's Avatar
    Feb 2006
    Same boat here. The Kress looks pretty attractive (dual nose bearings and all) and is available for a pretty good price from many dealers.
    I had retrofitted my Proxxon spindle with a hybrid ceramic nose bearing and was using it exclusively with 1/8" shank tools with distance rings for a mini-TTS experience (i.e. pre-set tool lengths in the tool table) with great results, but I was using it with coolant and apparently didn't clean it off well enough before I put it in storage, and the spindle nose rusted in the meantime. Not too badly but I will give electrolytic rust removal a try.
    But I'm seriously thinking of moving up to either a Kress 850 or 1050 with a homemade bracket.
    Machining with a .020" carbide endmill in aluminum at 4500rpm and 0.8ipm is for the birds...
    Randy
    Jun 2006
    Stavanger, Norway
    I know these are UK based but I'm sure you can find the same in the US of A. Probably at $ for £ prices.
    High Speed Spindles, Motors & Inverters - Arc Euro Trade
    Phil
    Jul 2004
    I adapted a wood router that has variable rpm up to 25k rpm and 2hp using some custom er adapters. It works really good! I have the mount designed if someone wants to make one.
    David
    Dec 2010
    I just started using an AIR TURBINE SPINDLE™ 602JS 40,000 rpm on my X3 with AMAZING results. it had 3/4" shank so I added a tts kit to it and can leave my tool in it, and throw it back into the spindle later to engrave without having to zero, plug anything in, remove mounts.
    Been using .0625" EM 3FL @ .02" DOC running at 30-50 ipm and the finish is great. Engraving speeds were slightly slower but only because I use single flute engravers. A multi flute could be run practically at the 1100s rapid speeds (at your own risk).
    The biggest thing for me was not sacrificing table space by mounting something on the side of the head, plus having to change offsets would seem annoying. I just program the high speed spindle like any other tool... only at lightning speed.
    I got a deal on two of them and did post a brand new (old stock) one on the bay with a 5 micron pre filter, oil separator, wrenches, and fitted foam lined case. if your interested pm me and I can pull it off the bay and give you a "friendlier" price. Its still the best deal I have seen, but more than I actually have into it as I don't NEED to sell it.
    Jan 2007
    I use a Bosch trim router.
    You can buy precision collets for it, fairly industrial, variable speed
    Works well for engraving and 3d surfacing (light cuts)
    Mooser
    Sep 2009
    Bosch Trim router
    @ Mooser
    Me too. Built a clamp-on-the-spindle holder, variable to 30K, but it does eat some working space. Same router was used at HSM several years ago to drive a lathe grinder. Compact, reliable, reasonable price. BTW- same hole more-or-less fits an older Dremel (280). Nothing special about the holder- 1" 6061 and a couple big holes. Early project.
    Air Turbine would be nice- but for an occasional use, just too much money.
    Registered Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    The air spindle looks like the perfect solution and for a paltry $2.2K. Wonder if any amateurs have posted plans for a DIY model perhaps modeled on a simple to build Tesla turbine.
    Don
    Dec 2010
    I tried mounting my dremel... too much vibration. Then I tried the dremel wand (below) with the body of the dremel on a pully so the whip was strait... too much run out. I was planning on getting a Kress, but then I got a deal on two Air Turbine Spindles that I couldn't pass on. I can sell the new one and end up worth a used one for $500ish - which will make me smile. I'm in the process of re-wiring the shop for 240v so I can get a compressor that can handle the spindle AND my mist system.
    ...giant added bonus: An 1100 will just fit in the back of my one car shop with the delux stand. When I have the power to run it I'm out of excuses not to buy one. Well, other than the $ keeper. But I've been carefully planting the seed that a larger mill with a tool changer means less time standing there, more productivity, and in turn more than one night a week I quit working befor 10:30. Down side is that night will likely be spent trying to ignore the Housewives Of Atlanta ::shudder:: Fair trade?
    Feb 2006
    A couple of posts/threads about concentric high-speed spindles (like the Speeder but independently powered):
    The Home Shop Machinist & Machinist's Workshop Magazine's BBS - View Single Post - Help...High Torque small diameter elec motor needed
    Good High Speed Spindle
    Randy
    P.S. Don, the Tesla is electric, not turbine. And it has ~80 lb-ft at 12krpm. That would be some interesting HSM...
    Feb 2006
    Go to ebay and search for "spindle motor and inverter". You will get lots of high speed chinese spindles to choose from - both air and water cooled.
    Jeff
    Jun 2006
    Quote Originally Posted by Don Clement View Post
    Don
    You have a very dry sense of humor - almost no vermouth at all.
  • Page 1 of 4 1234 LastLast
    1. A Right-angle Auxiliary Spindle for Deburring Long Tubes
      By SteveKoerner in forum Tormach Personal CNC Mill
      Last Post: 01-05-2012, 10:27 PM
    2. Spindle Recommendations
      By TZak in forum LinuxCNC (formerly EMC2)
      Last Post: 09-29-2011, 10:31 PM
    3. Controlling the Proxxon auxiliary spindle
      By zephyr9900 in forum Tormach Personal CNC Mill
      Last Post: 04-11-2009, 02:21 AM
    4. Spindle Recommendations
      By MayanArch in forum Wood Working Tooling
      Last Post: 01-01-2009, 10:03 PM
    5. Spindle recommendations
      By seansear in forum DIY CNC Router Table Machines
      Last Post: 09-02-2006, 12:27 AM
