Results 1 to 5 of 5
Thread: Lost or corrupt file
    Aug 2005
    I used my PCNC 1100 up until this past week. I went out to the garage to play some more and the computer will not boot. Error message reads " Windows could not start because the following file is missing or corrupt sys32\drivers\isapnp.sys".
    I have contacted Tormach about the issue but would like to use the machine today Sunday instead of waiting until Monday for Tormach to respond.
    Has anyone had this problem? Is there an easy fix? Start in safe mode? What then? I am not a computer expert so go easy on me.
    Thanks,
    Ernie
    Registered dbrija's Avatar
    Nov 2010
    Quote Originally Posted by ErnieD View Post
    Thanks,
    Ernie
    Is this a Tormach controller, or your own PC? My experience with that kind of message is usually a failing hard drive or corrupted operating system. I have saved a system before with a Windows repair from the install disk, but the drive totally failed within a few days anyway. On another I did the repair and its still running today.
    If its a Tormach controller under warranty, I'd likely wait for them to give you a course of action.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    To get to Safe Mode, hit F8 just as Windows starts to boot up. You should get a menu with boot choices.
    Once in safe mode, run Scandisk with a surface scan. This takes a bit, but will find and correct any problems with your hard disk that might have caused the file to corrupt.
    Meanwhile, I can go to my Tormach and get that file off of it, then email it to you. Just send me a private message with your email address.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Aug 2005
    File
    Hi TXFred,
    PM sent.
    Ernie
    Aug 2005
    dbrija
    Tormach / Dell compiter out of warranty.
    Ernie
    1. Need Help!- Corrupt programs?
      By Most in forum Haas Mills
      Last Post: 01-29-2012, 11:57 AM
    2. corrupt files on 18i-mb
      By ikennedy in forum Fanuc
      Last Post: 11-21-2011, 05:41 PM
    3. Lost xml file settings after upgrading mach
      By jsheerin in forum Mach Software (ArtSoft software)
      Last Post: 03-17-2011, 09:18 PM
    4. Need Help!- Corrupt Software
      By ericwaa in forum Milltronics
      Last Post: 10-08-2009, 05:30 PM
    5. Mastercam X corrupt file
      By tstrajt in forum Mastercam
      Last Post: 09-04-2008, 05:41 AM
