I have no experience with probing but I am sure you could do it with some macro work.
For location just bolt something to the table as a work stop and use a gauge block as a specer between the stop and your piece. Obviously you will take the gauge block out so your stop will not interfere with your machining operation.
I have also used the shank of an endmill in the spindle as a work stop when it is convenient.
Matt
LinkBack URL
About LinkBacks
