Results 1 to 7 of 7
Thread: Newbie alignment issues
    Aug 2006
    Hi guys,
    I am trying to cut parallel edges on both sides of a 1/4" plate. I hold it in my vice and take a pass on one side with my 1/2" end mill.
    I get a very nice clean cut and I mark this location as 0.25" (half my cutter width), now I scroll to -6.85" inches to the other side, and make a cut, take another pass at -6.75" and measure.
    I'm seeing 6.48" using my digital calipers. I tried this a few times taking light passes thinking maybe it was tool deflection or something but it doesn't appear to be so. I know that my tool might not be exactly 1/2" but with this method, i would have thought it would have errored on the greater side.
    I'd appreciate any ideas on where I might look to solve this issue.
    Jun 2006
    Stavanger, Norway
    What mill are you using.
    Phil
    Registered Gerry Sweetland's Avatar
    Feb 2008
    Never mind :-)
    Red hair and black leather, my favorite color scheme...
    from Vincent Black Lightning 1952 by Richard Thompson
    Jan 2012
    run out
    Is the tool runnimg true? or how much run out is there?
    Aug 2006
    philbur: This is a Tormach PCNC1100 Series 2 with upgraded motors.
    g3jeff: I put a dial indicator on the tool and spun it and see less than 0.0005" of run-out. The bit is held in a 1/2" TTS holder.
    The tool is an OSG 541-1100 4F Cobalt cutter with a 1.25" LOC.
    Jun 2008
    Is there any chance it could be a backlash issue or a setting in Mach3 that is compensating (or over-compensating) for backlash? I haven't performed the backlash setting procedure on my machine yet so I'm pulling this info out of some vague memory and it may be way out in left field.
    Good luck and I will be definately interested reading the solution.
    John
    Jun 2006
    Stavanger, Norway
    Check the axis movement corresponds with the DRO by using a dial indicator. Run the same path as the part with the error (including start and finish directions, to allow for potential backlash).
    With a DI and a bit of thought it should be easy to find where the error is.
    Phil
    1. APC alignment issues
      By dingo0722 in forum Haas Mills
      Last Post: 09-05-2011, 02:13 PM
    2. Mitsubishi DWC alignment issues...
      By bluedemon in forum General Waterjet
      Last Post: 06-26-2011, 11:11 PM
    3. Newbie - Issues please help
      By TheBulk in forum DIY CNC Router Table Machines
      Last Post: 03-06-2011, 04:27 PM
    4. Replies: 1
      Last Post: 12-09-2010, 02:15 AM
    5. Alignment and squareness issues
      By boxwood in forum DIY CNC Router Table Machines
      Last Post: 08-23-2003, 09:20 PM
