I saw a 3+2 setup somewhere on a tormach.
If I purchased two 4th axis drives, and mounted them in a trunnion arrangement, can mach 3 handle this alone? Or is this wishful thinking.
No you need..
another breakout board and 12V psu
another DC Bus board
another panel mount din connector
and another parallel port card for the computer.
and some rum.
Oh, ok, thanks man.
I dont like 5th axis's any way.
Hi Andrew
You may be talking about this. http://www.cnczone.com/forums/tormac...p_running.html
Mach can handle 6 axis. But the Tormach control board does not have enough inputs for the 5th or 6th. And as stated you will need some other stuff as well.
It is doable with a fair amount of work.
Scott
www.sdmfabricating.com
