Results 1 to 7 of 7
Thread: Capturing flute length (max depth of cut) in SprutCAM
    Feb 2011
    I'm trying to better detect tool holder collision and exceeding the length of my flutes on some tools. I think Sprut could alert me to any oversights if I put more info into the SprutCAM tool library.
    At first I thought setting the tool length "L" equal to flute length might be a good approach. Then make the remainder of the tool shank part of the tool holder, followed by the TTS geometry itself. But that breaks the reusability of tool holder types across tools (meaning, I'd have to define a holder for each tool, not just once per holder type).
    How do you handle this?
    Thanks,
    Dave
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    L is flute length. You edit the Overhang value to adjust how much of the tool sticks out of the tool holder.
    Overhang is actually the overall length of the tool holder, from the TTS shoulder to the end of the tool. So it's the same value as what you'll measure when you put the tool holder and tool on the Tormach surface plate and measure it with the height gauge.
    You are right. Sprut will detect when the shank of a tool collides with the workpiece.
    Pictures being worth a thousand words, here's three examples; the standard Tormach face mill, a 1/2" end mill, and a homemade slitting saw.
    Attached Thumbnails Attached Thumbnails Capturing flute length (max depth of cut) in SprutCAM-facemill.jpg   Capturing flute length (max depth of cut) in SprutCAM-endmill.jpg   Capturing flute length (max depth of cut) in SprutCAM-slittingsaw.jpg
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Feb 2011
    Thanks TXFred. I get it now.
    Dave
    Feb 2011
    OK, I spoke too soon. I think I totally understand the setup of the tool and holder. And Sprut does give me a "contact with holder" warning on the toolpaths.
    However, I just created a tool with .5" flutes (L) and .5" of shank showing before the holder. I can see in the tool library drawing .5" of yellow (L) and .5" of white (shank) and my holder, so I'm sure I entered the cutter data properly.
    Sprut had no problem allowing me to make a .75" deep pocket in one pass. That would not work in real life.
    Have I missed something, or is it just not that smart?
    Dave
    Aug 2009
    Austin, TX
    That's strange that Sprut did not catch that. I've had it flag similar issues on several occasions, albeit not during a pocketing operation. Usually it's during a contour or surfacing operation.
    What version are you running? I'm on Sprut Version 7, Build 1.5, Rev 45786. It seems to be a minimally buggy version.
    By the way, there's a dedicated SprutCAM forum here on the Zone. There's lots of good advice and helpful people there. You'll get more info there than here, since not every Tormach owner uses SprutCAM.
    SprutCAM - CNCzone.com-The Largest Machinist Community on the net!
    Cheers,
    Frederic
    Feb 2011
    Frederic,
    When you found my other problem (thanks! and I actually posted that one to SprutCAM forum), I upgraded from 7 build 1.2 to build 1.6 (the current as of that day). That did fix the previous problem.
    Now today I tried to revert to build 1.5, which you seem to be having good luck with. Now I'm all jacked up. My projects opened in 1.6 won't open in 1.5. So, I have re-installed 1.6.
    I hope it's not any less stable/useful than 1.5.
    Dave
    Aug 2009
    Austin, TX
    Quote Originally Posted by gsnorcal View Post
    I didn't catch on that those two threads were from the same person.
    I think that's pretty bad that you can't go back to 1.5. I'm glad of the warning. I'm going to avoid upgrading for a while.
    Frederic
    1. Capturing that last bit of plasma smoke from water table?
      By landmark in forum General Waterjet
      Last Post: 01-03-2011, 12:35 AM
    2. Capturing True Part Cost?
      By stopncrank in forum WoodWorking
      Last Post: 06-28-2010, 02:15 PM
    3. newb talk, 2 flute vs 4 flute cutters
      By DerHammer in forum General Metalwork Discussion
      Last Post: 05-05-2009, 05:01 PM
    4. When do I use 2 flute and when 4 flute?
      By slashmaster in forum General Metalwork Discussion
      Last Post: 05-02-2009, 07:31 PM
    5. Depth setter / tool length input?
      By thackman in forum Syil Products
      Last Post: 06-26-2008, 05:08 PM
