Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Tormach T/C Tapping head... defect?
    Nov 2007
    I purchased a Tormach T/C Tapping head a few weeks ago to tap a bunch of 6-32 holes but I'm breaking taps every 10th hole or so. I tried Sowa spiral point and spiral flute and both are breaking on me.
    I noticed my T/C tapping head is smooth on the downward float compression but binds 1/3 way up on the upward float compression. I'm wondering if this is normal.
    Can someone with a T/C tapping head check theirs to see if theirs work the same way?
    I've already got a email to Tormach but I think I won't get a reply until Monday being Thanksgiving.
    Also... how tight should the clutch be set? I noticed on the downward tap... it goes down smooth but on the upward, the float is working more and my tap seems to be breaking at about 1/3 way up on the float (where the bind is).
    See video for more details.
    Thanks!
    Ken
    Feb 2007
    I hear a little bit of a kink in the spring pulling outward, but I don't think this should have any effect as long as your code is correct.
    I have the same tc head and have never had any problems like that. A little video or pictures helps solve the problem faster. What was your dwell time ? What type of material are you tapping ? Coolant on, oil, etc. ?
    Lets see your gcode...
    Nov 2007
    The kink is what I'm suspecting is the problem. It taps down fine but every 10 or so taps, when the tap is spinning out is when I'm snapping taps. The TC head will also sometimes get stuck on where it kinks making the Z lower by about 1/4" on the next hole. If I tap the TC head with a pencil, it'll snap back up to where it should be.
    I'm tapping 6061 Alu but going 1/2" deep. Tried with coolant, tapping oil and WD40... tapping fluid works with best. Below is my code... hope you can shine some light on my problem.
    G80
    G91 (G28 Z0)
    G90
    M01
    N2 M6 T30
    G90 G00 G40 G54
    G43 H30 D60 G0 X1.649 Y1.293 Z2. S300 M3
    M8
    (T30 6-32 TAP HOLES - DRILL)
    X1.649 Y1.293 Z0.4
    M29 S300
    G98 G84 Z-0.65 R0.4 P0 F9.375
    X2.169
    X2.689
    X3.209
    X3.729
    X4.249
    X4.769
    X5.289
    X5.809
    X6.329
    X6.849
    X7.369
    X7.889
    X8.409
    X8.929
    X9.449
    X9.969
    X10.489
    X10.413 Y0.187
    Aug 2009
    Hello Ken,
    I had a similar problem with my TC head that I posted on previously:
    Learning How To Use A TC Tapping Head
    A circlip in the spring mechanism is the most likely issue.
    If you are game to disassemble you'll problem get to the stage where you taken off the ball cage and can't figure hot to get it apart further. There's a small hole through the centre long axis. At the end of the hole is a small slotted head machine screw that keeps the T/C assembly together. It took a while to get a small slotted head screw driver that was small enough to fit but was strong enough to do the job. The machine screw is set with a lot of torque so its hard to get a purchase with the small screw driver. I found the best way was to hold the screw driver in a vice and turn the T/C assembly itself.
    When you do get it apart you'll come across the two spring t/c mechanism. Careful when undoing the circlip here as soon as it loosens you have a spring, washer and circlip shooting across your workshop.
    Regards, Christian
    Nov 2007
    Thanks Christian, I'll have to look into that after thanksgiving. Was wondering if I should take it apart since the upward stroke did not feel smooth at all and had some binding. Good to know I'm not the only one with the problem.
    Ken
    Registered Scott_M's Avatar
    Apr 2006
    Medina , Ohio USA
    Hi Ken
    Have you written a custom macro for G84 ?
    Tormach does not support G84. On my machine the G84 call exhibits some really strange behavior. Like long pauses in all the wrong places. With no pause when the spindle reverses. My guess is your feed direction changes much faster then your spindle does and you are getting to the limits of the T/C.
    Unfortunetly there is no canned cycle for the T/C head. The most efficent way to do it would be to write your tapping in/pause/out code in a subroutine and call it at each hole location.
    Scott
    www.sdmfabricating.com
    Nov 2007
    Scott, No... I have not hand coded G84 before... actually... this is the first time I'm machine tapping. Before this, I hand tapped all my holes but this job requires hundreds of taps so I decided to try the TC Head.
    I'm relying on SolidCAM's G Code. And after your comment, it does seem dwelling is at the wrong places. As of now, the Z will spin to 300rpm... wait 3 seconds and go down... and as soon as it reaches Z-0.5 (bottom), spindle reverses right away with Z going up at the same time. Once it reaches Z0.4, it stops for 3 seconds before moving X,Y to the next hole and immediately Z moves down and the cycle continues.
    Ken
    Feb 2007
    Once I get back home I'll post the code that works for me, maybe it will help. I'm thinking it could be a dwell time issue only because I barely pull the shaft out of my TC head coming up. let me double check my notes...
    Apr 2006
    Medina , Ohio USA
    Quote Originally Posted by apeman88 View Post
    Ken
    That is exactly what I am talking about. The G84 cycle is for rigid tapping. The Tormach does not support it. The T/C head needs about a 1/2 second dwell at the bottom before it feeds out to give the spindle time to get up to speed.
    I believe you are getting to the limit of the T/C heads "float" this is why you are breaking taps.
    If I knew how to write a Macro I would make one for a Canned cycle for the T/C tapping head it really needs one.
    Just a thought...I wonder if you intentionally gave it the wrong feed rate so it would "load up" the head to prepare it for the lack of dwell at the bottom, it may make up for the missing travel.
    Scott
    Feb 2007
    This is for a 8-32 through hole and sure with the right clearance you could pull a blind hole off. I'd say .3" clearance would be min for a cutting bottom tap, form bottom tap you could get away with .2 maybe less. Hope this help, good luck with it. Post your parts final results !
    ( 8-32 tap )
    ( T18 : 0.164 )
    M09
    M998
    T18 G43 H18 M6
    M3 S500
    M08
    G0 Z0.05
    G0 X-2.1584 Y0.0
    G0 Z0
    M3 S500
    G4 P4
    G1 Z-0.62 F15.625
    M4 S500
    G4 P0.5
    G1 Z0.1
    Nov 2007
    No... I'm positive I'm not reaching the limits of the floats. When it starts the reverse, the spindle does catch up fairly quickly... but once every 5th hole or so... the clutch on the TC head slips and I'll reach about 1/3 of the float where the kink is and half the time, It'll snap the tap.
    I will reprogram mt code for 1/2 second dwell at bottom of the tap and see if it helps.
    SolidCAM self calculated a feed of 9.375 when I put in 300RPM for the spindle. I did double check this number and it is accurate... right?
    Ken
    Nov 2007
    Thanks Twocik... looks like I have to mod my codes and get it a try again.
    Ken
  • Page 1 of 2 12 LastLast
    1. Reversing Tapping head vs Tension/Compression tapping Head
      By apeman88 in forum Tormach Personal CNC Mill
      Last Post: 01-25-2011, 09:39 AM
    2. Tapping with the Tormach Tapping Head
      By bobs_charger in forum Tormach Personal CNC Mill
      Last Post: 04-24-2009, 05:08 PM
    3. Tapping head or rigid tapping
      By Gregory_C in forum Syil Products
      Last Post: 10-18-2008, 01:49 AM
    4. Rigid tapping or tapping head
      By wildcat in forum Industrial Hobbies (Support forum)
      Last Post: 09-24-2006, 01:08 PM
    5. tapping head vs hand/cordless tapping machine....
      By InspirationTool in forum General Metal Working Machines
      Last Post: 09-12-2005, 09:10 PM
