Results 1 to 3 of 3
Thread: Tormach 4 axis?
    Dec 2007
    Tormach 4 axis?
    Does anyone know if you could change the stepper motor to a servo type motor on the 4th axis from Tormach? The price is good on these 4th axis used servo driven models are $3k and up. I have been considering buying a Tormach PCNC 1100 but I am leaning towards a used bed mill and I have a need for a 4th axis the Trak Mill I am looking at has a 4th axis driver but it is for a servo type motor with a 5 volt output and return.
    Thanks Mike
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    I don't see any reason why a servo could not be used in place of the stepper. The stepper is a NEMA34, so a NEMA34 servo should bolt right on.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Dec 2007
    The more I look into this the more I think it may work according to the data sheet the worm gear is 90:1 and the RPM of the table is 5 aprox. If I figure this right that means I need a 450 RPM servo motor with a nema 34 frame. I will check with Tormach just in case they offer it with a servo motor.
    Thanks Mike
  1. New Tormach 1100 won't reference Z axis
    By ernest poland in forum Tormach Personal CNC Mill
    Last Post: 09-10-2011, 04:29 AM
  2. Tormach 4th axis
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 02-15-2011, 09:18 PM
  3. Moving Part Independent of 4th axis tbl *Tormach*
    By HLF Ordnance in forum SprutCAM
    Last Post: 02-13-2011, 07:42 PM
  4. cut 2d and Tormach
    By Etced in forum Vectric
    Last Post: 01-19-2011, 08:10 AM
  5. Build Thread- building a 4th axis for tormach
    By highspeedmazak in forum Tormach Personal CNC Mill
    Last Post: 09-05-2008, 12:19 PM
