I have never had much luck with multi flute champfer bits. Especially on the smaller diameter near the point just not enough chip clearance on the flutes to clean adequately. You might try a single or two flute champfer mill. There are lots of them for reasonable prices. If you are smearing metal that is a guaranteed sign that you are not clearing chips and melting metal to the cutters edges welding it in place. Are you using coolant as well? I have seen some good success in youtube videos with two flute triangular insert champfer mills at full stink spindle speed and a slightly slower feedrate. Have not tried it myself but intend to soon. Good luck and peace
Pete
LinkBack URL
About LinkBacks
