Results 1 to 8 of 8
Thread: Cutting 3" deep pockets - no finishing pass?
    Oct 2011
    I'm looking to cut an aluminum mold with pockets nearly 3" deep. Try as I might, I'm not finding narrower endmills to perform a finishing pass long enough for this.
    I'm starting to think now that the way to do this is to not have a finishing pass, but to use the full size endmill for the entire cut. So I'd have to find a CAM setting to have the mill follow the path of the wall, to get a smooth finish on it.
    Is this a good approach to the problem? Anyone know the setting to get this style of toolpath out of VCarve Pro or Cut3D?
    Jun 2006
    Stavanger, Norway
    I might be missing something but isn't this the basic function of all CAM applications?
    Any slight step, due to a DOC that is less than the total depth, will have to be blended by other means.
    You can have a finishing pass for each pass which will reduce deflection and therefor the size of the step to be blended.
    Phil
    Quote Originally Posted by baudot View Post
    Oct 2011
    The CAM software I've used so far (VCarve Pro) has plotted a toolpath that moves in rows across the surface being milled, more like a dot matrix printerhead than a plotter, if you will.
    Jun 2006
    Stavanger, Norway
    I think you may have the wrong CAM program for creating molds with pockets 3" deep. VCarve Pro appears to be for engraving.
    Phil
    Oct 2011
    Quote Originally Posted by philbur View Post
    Which programs do you recommend?
    Gold Member hoss2006's Avatar
    Apr 2006
    baudot,
    When you setup your pocket toolpath enter a value in "pocket allowance" like .015
    to leave .015 material.
    Then create a profile toolpath, inside machine vector and set your selected tools "pass depth" to 3.0.
    That will take the .015 material off in one pass.
    That's hella deep so chances are it's gonna chatter though you didn't say what diameter tool you're using.
    Maybe set the pass depth to 1.0 or 1.5 to have less lines to blend.
    Also, in future you'd be better off asking in the Vectric forum than here.
    Vectric - CNCzone.com-The Largest Machinist Community on the net!
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jan 2009
    Under "Pocket toolpath" select "Offset" instead of "Raster".
    You will then get a toolpath that traces around the perimeter instead of back and forth.
    Also, you can draw a very narrow offset inside the pocket boundary and make a separate clean-up path. You can use Profile- cut inside of line for a 0.001 or so finish cut.
    For any cut in metal, be sure and ramp your cut entry.
    Dennis
    Dec 2007
    Can you post a picture or a file? I use Vetric Aspire for my CNC router table there are several ways to accomplish your pocket and a finishing pass the use of leads to enter the cut and ramping is another method depending on the part geometry. You can save a offset vector on a different layer in the cad drawing and tool pathe that vector there is a bunch of ways to accomplish your finish pass. How large is the pocket and how big is the bit (length & diameter)?
    Mike
    1. Deep pockets
      By AirAce in forum General Metal Working Machines
      Last Post: 05-08-2011, 02:03 PM
    2. Deep Pockets
      By BlueFin in forum Tormach Personal CNC Mill
      Last Post: 03-20-2011, 01:42 AM
    3. Newbie- Vcarve pro finishing pass?
      By magudaman in forum Vectric
      Last Post: 02-06-2011, 11:29 PM
    4. Need Help!- pocket milling - don't want finishing pass
      By jay_dizzle in forum BobCad-Cam
      Last Post: 10-15-2010, 04:13 AM
    5. the finishing pass
      By inthedark in forum General Metal Working Machines
      Last Post: 02-16-2004, 06:58 PM
