Results 1 to 3 of 3
Thread: Z axis brake question
    Jun 2006
    Stavanger, Norway
    I assume the lever on top of the z axis brake is to allow for manual brake release? Does anybody know which lever position is which. I can't find anything in the manual.
    Phil
    Aug 2005
    Manual Brake Disengage
    The brake can be manually disengaged by turning the lever left or right just a bit. Less than 5 degrees will do it. Looking at the top of the manual brake lever you can see a couple of indentations. Those line up with holes in the cylinderical brake body. By rotating the handle the indentations bring the handle up by about 2 mm, compressing the internal spring and releasing the brake.
    Another good brake trick is the method we sometimes use to make sure the electrical brake action is working. There is a small motion of the manual brake lever every time the brake is electrically released. The motion is so small it's hard to see. If you set a small coin or washer on the manual actuation handle, you should see the coin flip off when the machine is turned on. This is a positive indication of the brake release.
    G. Jackson
    Jun 2006
    Stavanger, Norway
    Thanks for that.
    Phil
  1. Newbie- Z-Axis Brake? Huh?
    By firstyear in forum Servo Motors and Drives
    Last Post: 09-08-2011, 01:44 AM
  2. Need Help!- Z Axis Brake? Huh?
    By firstyear in forum General Electronics Discussion
    Last Post: 09-03-2011, 07:22 AM
  3. Press Brake Question
    By sodfarmer in forum Bending, Forging,Extrusion...
    Last Post: 01-08-2011, 10:57 AM
  4. New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging,Extrusion...
    Last Post: 09-06-2010, 11:56 AM
  5. Arcane brake solenoid question
    By Mr. Technical in forum Bridgeport and Hardinge Mills
    Last Post: 10-08-2009, 05:35 PM
