Results 1 to 5 of 5
Thread: Moving a PCNC 1100
    Feb 2011
    Moving a PCNC 1100
    Anyone have thoughts on moving an assembled PCNC 1100? If I put it on a flatbed trailer, would it survive an 1100 miles journey? Can it be secured enough without the straps putting too much stress where is doesn't belong?
    Anyone have experience moving one a long distance?
    Thanks,
    Dave
    Jun 2008
    When I asked Tormach the same question they cautioned that the tabs that the adjustable legs go through are not welded robust enough to handle much strain (ie bouncing along on a trailer).
    I'm sure some blocking would easily fix that problem though.
    John
    Jul 2007
    It isn't a lot of work to remove the machine from the stand so at a minimum do that. Also use a couple of straps and maybe some duct tape to hold the control panel door shut and unlock it. I hit a bump when moving mine and it broke the latch on the door lock. It wasn't expensive to replace but I had to order the part from Tormach.
    bob
    Mar 2010
    Moving Tormach 1100
    I just moved one 1000 miles on the back of a 3/4 ton truck with no problem.
    Placed a wood block between the spindle and table. Cross strapped to each
    corner across the head, and everything is fine. Did not disassemble anything.
    Oct 2009
    I have a custom enclosure on mine and it would have been torn up by the turbulence of the highway. I rented a Budget Truck with lift gate and used a pallet jack. It was easy but loading was stressful. I had to take the Z-axis motor off, BTW.
    1. New Series 3 PCNC 1100
      By Wog in forum Tormach Personal CNC Mill
      Last Post: 04-23-2012, 03:51 PM
    2. PCNC 1100 help
      By jedge in forum Tormach Personal CNC Mill
      Last Post: 10-23-2010, 06:58 PM
    3. Rapid with PCNC 1100 and 770
      By concombrefrais in forum Tormach Personal CNC Mill
      Last Post: 10-12-2010, 05:56 AM
    4. For those of you with a PCNC 1100
      By HLF Ordnance in forum Tormach Personal CNC Mill
      Last Post: 01-01-2010, 06:51 PM
    5. What do you think of the New Tormack PCNC-1100
      By Willyb in forum Benchtop Machines
      Last Post: 03-20-2006, 10:31 AM
