Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: Thinking of buying some TTS tooling...
    Aug 2006
    UK
    Hi guys, I don't have a Tormach mill, but I am very tempted to invest in some TTS tooling.
    I'm not sure whether to just go for the full CNC set (in metric) or to just put together a set of tools myself. I live in the UK, so shipping costs are an issue (that's good tool money!) so I am half tempted to drop the surface plate, height gauge and drill chucks (but not JT adaptors).
    I already have a height gauge - is the Tooling Assistant a real benefit, or just nice? I'm not running Mach 3, so am I right in thinking their height gauge and USB dongle would just save me transcribing the height readings into the PC?
    Also, which toolholders do you guys wish you had more of? I've always been a fan of collet-chucks, but they are rather pricey, and TBH I've probably used them more as compact chucks to hold my favourite drill sizes than to hold odd endmill diameters.
    Cheers.
    Feb 2008
    You should check Quick Change Tooling for TTS ER20 holder. I have a bunch and I am happy with them. Smithy also sells TTS holder, some cheaper than Tormach: Smithy
    Christian
    Sep 2005
    I initially bought the larger set with the height gauge and plate but would buy differently if I were doing it today (especially if shipping over the ocean).
    I personally don't like the holders with the fixed size holes unless it's just to hold an indicator or something like that. I also have not used their height gauge or the surface plate as I already had those items. For the drill chucks in the set there are only 1/2 inch and 1/4 inch, to me 3/8 are much more useful.
    The TTS collet chucks (ER20 and ER16) along with the JT-x taper holders (3/8 inch chucks) are my most used items. I also made some collars for some of my 3/4 inch tools so I have the TTS feature without a holder (I posted pics here a while back).
    Robert
    Feb 2006
    The Tooling Assistant software is not really worth the bother - I used it once or twice, and now just manually input the numbers into Mach3. Trouble is, TA writes a tools file, but to load it into Mach3, you have to exit, and restart, Mach3. Entering the offsets manually works just as fast.
    Regards,
    Ray L.
    Aug 2006
    UK
    Quote Originally Posted by concombrefrais View Post
    Christian
    Thanks,that is very cheap, but it does look to be lacking the ATC grooves, which I think I'd like to have. Novakon also seems to be out of the ER20 holders.
    Aug 2006
    UK
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Cheers - I think for my use, I'd probably be happy enough measuring the heights in the 'shop and then writing them down or punching them into a text-file. I don't have a Windows machine anywhere near my mill.
    Aug 2006
    UK
    Quote Originally Posted by RTP_Burnsville View Post
    Robert
    Yeah, I've never used set-screw mill holders myself - I'm not totally against them, but I do prefer ER-collets.
    Hmm, I'm going to have to look at some of the parts I've made and am planning to make and then try to work out what my most common toolsets are.
    Jul 2004
    Christian
    Im sure you are trying to save the guy a buck, but it seems a bit in poor taste to post another mfg tools in this forum when they are asking about the Tormach brand in a Tormach forum. Especially since Tormach invented the system and apparently has been knocked off.
    David
    Jun 2007
    David
    I consider it a favor. Both companies advertise here. This particular tool similarity has been listed several times in the Tormach list. So has Shars and Glacern. Again, I don't always know the options, so I find it helpful when someone provides options.
    Aug 2006
    UK
    Luckily for me, the cheap ER20 holders are out of stock, so I don't need to test my moral compass for alignment
    They also seem rather too cheap to me, and I have learnt the hard way that it's better to buy expensive tools cheaply (e.g. second hand) than just buy cheap tools...
    I also would feel bad about buying knock-off TTS, but then again I have no qualms about buying generic Cola - I'm a hippocrite, I admit it!
    That said, I do think the TTS ER-collet chucks are rather pricey - why is there a $20 premium for ER20 over ER16? Maritool seem to be highly regarded on here, and their straight-shank ER-collets are sub $60, which feels more like it to me...
    Then again, everything is relative - a tank 45L tank of petrol is pushing $100 over here - it makes most other things seem rather reasonable...
    Jul 2004
    I totally understand your point. I design, mfg custom parts, that I sell into niche markets and know the tremendous amount of time it takes to develope the simple stuff I do. If someone were to take my idea, replicated it and undersell me... well I guess Id be a bit upset about it. Thats the only reason I wouldnt promote companies selling the copies, especially in the creators forum.
    If it were a part that wasnt blatantly ripped off but an original design, I wouldnt have the same feeling about it. To each his own I guess.
    David
    Jul 2004
    Digits, I have a ton of the setscrew holders and have been really happy with them. I use the ER20 and ER16 holders for .1875 and smaller cutters(and engravers).
    It may be benificial for you to have the ER style holders depending on your work, but for the stuff I do, its not even remotely an issue.
    If I was going to purchase more ER style holders, they will be ER16 for the above reasons. Much more reasonably priced.
    David
  • Page 1 of 3 123 LastLast
    1. Need Help!- Thinking about buying Bob Cad
      By Gmaan in forum BobCad-Cam
      Last Post: 08-10-2011, 04:15 PM
    2. Need Help!- thinking of buying a dynatorch?
      By Tormachmaster in forum DynaTorch
      Last Post: 03-13-2009, 10:20 PM
    3. thinking about buying pro-e
      By cncclimber in forum PTC Pro/Manufacture
      Last Post: 09-08-2008, 12:25 PM
    4. Thinking of buying an ELU 860 CNC
      By less_is_more in forum CNC Machining Centers
      Last Post: 09-07-2007, 01:59 PM
    5. thinking of buying sx3
      By madaouk in forum Syil Products
      Last Post: 06-18-2007, 08:35 AM
