Results 1 to 6 of 6
Thread: mach 3 on new PCNC770 wont go out of demo mode with license installed...
    Sep 2011
    I have had my PCNC 770 for about a week, finally got to a program with more that 500 lines. It stops at 500 lines. Under HELP it shows I am still in demo mode. Tried manually pasting license in the mach 3 directory and then pcnc directory still no change in demo status. I tried by the directions first of putting in cd and letting it put license where it should . I did that it showed a dos prompt and said it was installed and then closed. I rebooted several times and no change in demo status. Ra program and stopped at line 500. Anyone else had this problem?
    Feb 2009
    I had the same problem with my 770 when I first started using it. I also couldn't access the "extra" program for changing settings (changing probe to break a circuit on contact or not, etc.) I remember getting an error when I tried opening that program and doing a search on the error and was directed to download an update for XP and a little command prompt stuff and moving the file into the proper place fixed it. I would contact Tormach about this as I don't remember all the specifics but it did work even though Windows gave me an error message as I was doing the updates. Good luck.
    Sep 2011
    Quote Originally Posted by n1k86 View Post
    Thanks, I will be contacting them first thing in the morning, I lost the whole weekend not being able to go past 500 lines...
    May 2011
    Santa Cruz, CA, USA
    Temproary workaround... subprograms. You can write VERY long and complex programs in very few lines. I realize that it doesn't solve the problem, but you can get work done that way (assuming you haven't solved it already)
    Jun 2006
    Stavanger, Norway
    What was the solution?
    Phil
    Sep 2011
    Quote Originally Posted by philbur View Post
    Phil
    Called Tormach, they sent me a new license key, that did not work either, it stayed in demo mode. I finally got another desktop that is similar to the one I use. I loaded mach 3 then loaded the old key, it worked. It went out of demo mode. Unfortunately I lost so much time that when I got it to work after wasting the whole weekend I just used that one. I needed to make up for lost time and get some work done. So, I still need to remedy that situation on my work pc. My daughter is begging for her pc back ... I am stumped on that one but I need to figure it out but I cant afford to waste another 10 hours on it right now.....
    1. License question - Virtual PC XP mode
      By MBX5 in forum Solidworks
      Last Post: 02-28-2011, 04:02 PM
    2. Can X4 run in DEMO Mode?
      By Allen Thompson in forum Mastercam
      Last Post: 06-11-2009, 08:08 AM
    3. Need Help!- demo mode v23 why is it saying im in demo mode
      By chaz6966 in forum BobCad-Cam
      Last Post: 03-17-2009, 06:32 PM
    4. Hypermill 5.1 DEMO MODE only. Help?
      By Hemmi in forum Hypermill
      Last Post: 11-29-2008, 02:03 AM
    5. X in demo mode
      By mdlmkr in forum Mastercam
      Last Post: 10-28-2005, 09:53 AM
