Results 1 to 7 of 7
Thread: What is the current draw of the PCNC 1100?
    Sep 2011
    I see the voltage of the PCNC 1100 is 220 volts, I am wondering what the current draw is? I am trying to see what my box breaker and wiring would have to be rated at to have this one...
    Jun 2006
    Stavanger, Norway
    The spec says you need a 20 amps supply.
    Phil
    Quote Originally Posted by Smokey911 View Post
    Dec 2003
    I thought that was all cleared up here?
    http://www.cnczone.com/forums/tormac...y_770_but.html
    If you have the option of running on 240v and the spec is 20amps on 120, the on 240 it will be 10 amps.
    Oops, I see a different model?
    According to the 1100 manual it says current draw under 15amps but 20a recommended, usually the largest draw in a CNC is the spindle.
    Sep 2011
    Quote Originally Posted by Al_The_Man View Post
    No, this is a separate issue, I am running a new line in the garage and since I am going through the trouble I want to run a line that will give me the capability to run the other machine as well. I don't want to get this done, then turn around and have to run another line some months down the line.
    Dec 2003
    Well if you follow the manual, they recommend 20A, in spite of the claim it runs under 15A?
    What HP is the spindle on the 1100?
    If you intend wiring for both machines and also allow for other loads, then I would suggest running #6 3wire and ground with a 50A breaker.
    For load splitting you should have a local fused disconnect in the garage.
    Sep 2011
    Thanks for the response, I agree....
    Sep 2011
    Quote Originally Posted by philbur View Post
    Phil
    Thanks.
    1. Need Help!- Looking for alternative to PCNC 1100
      By Mantas in forum Want To Buy...Need help!
      Last Post: 07-19-2012, 05:30 PM
    2. New Series 3 PCNC 1100
      By Wog in forum Tormach Personal CNC Mill
      Last Post: 04-23-2012, 03:51 PM
    3. How to cut a rack on a PCNC 1100?
      By avayan in forum Tormach Personal CNC Mill
      Last Post: 05-20-2011, 04:31 AM
    4. PCNC 1100 help
      By jedge in forum Tormach Personal CNC Mill
      Last Post: 10-23-2010, 06:58 PM
    5. For those of you with a PCNC 1100
      By HLF Ordnance in forum Tormach Personal CNC Mill
      Last Post: 01-01-2010, 06:51 PM
