Page 1 of 5 1234 ... LastLast
Results 1 to 12 of 54
Thread: Tension/Compression Tapping Head??
    Dec 2007
    Can someone tell me how this works and how you generate the toolpath for it? Does the spindle actually reverse direction or stop and the spring loaded head unwinds I have never used one or seen it used.
    Thanks Mike
    May 2004
    There are two types. There is the compression/tension tap holder (mill or lathe). Then there is a tapping head (mill only). With the tap holder, it allows the tap some wiggle room to align with the hole and to allow for variations in the feed rate to spindle RPM ratio. This type would be programmed for the spindle to reverse direction and the infeed feed rate to be slightly less than the tap pitch and withdraw at the same rate as the pitch (works best). With a tapping head, the spindle runs constantly the same direction (normally clockwise). As the spindle feeds toward the work, the gears in the tapping head cause the tap to rotate in the same direction. As long as infeed is maintained, the tap continues to rotate in the same direction. When infeed stops and then reverses for withdrawing the tap, the tap rotation reverses. This would be programmed with the tap pitch as the feed rate for infeed and withdrawal.
    http://www.kirkcon.com/
    Feb 2006
    Quote Originally Posted by txcncman View Post
    I assume the tapping heads also include essentially a tension/compression feature, in case the mills feed is not a perfect match to the screws pitch?
    Regards,
    Ray L.
    May 2004
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    This is the idea, yes. "...to allow for variations in the feed rate to spindle RPM ratio."
    May 2004
    "Newer" machines with C axis encoders can actually use rigid tapping (usually M29). In this operation, the machine will match the C axis position with the tap position during acceleration/deceleration of the spindle, so a compression/tension tap holder or a tapping head is not really needed (or even usually wanted).
    Jul 2005
    Regards,
    Ray L.
    Yes. This is inherent in the design. A tapping head has a reversing gear train inside and provided the feed is forward the forward gear train is engaged and the tap rotates at the same speed as the spindle. When the feed is reversed the reverse gear train is engaged as the tap runs ahead of the feed and the tap is reversed out of the hole.
    A tapping head has a radius arm that has to bear against a fixed point and be able to slide down and up as the spindle moves. This arm is needed so the direction reversal can occur in the internal gear box.
    A tapping head can also be used in a drill press just using hand feed.
    Dec 2007
    I understand the concept I think, so the tapping head Tormach sells with their mills as an option does not require the spindle to change directions correct? The feed and speed would be a formula of the thread pitch correct? Is there a wizard that calculates this by entering the parameters tap size & depth to give the proper spindle speed?
    I ask these questions because I own a 3D cad/cam program now that is designed more towards cabinet & sign makers IMO Aspire by Vetric one of the things I want to be able to do is tap holes so I am wondering how this toolpath gets generated? I do not want to have to buy Alibre or Sprutcam if I do not need too. I am used to using this other Cad system and it has a cam feature built in. I am trying to figure out what I need before ordering a machine. The cad program has a drilling toolpath that allows for peck drilling and you can enter your feed and speed but you would have to know those numbers, and I am not sure how to figure that out.
    Thanks Mike
    May 2004
    Quote Originally Posted by Gundawg View Post
    Tormach seems to have both available. Tormach Tooling System - Tapping Heads and Collets | Tormach LLC | We provide personal small CNC machines, CNC tooling, and many more CNC items
    Speed is determined by both a chart and a formula. The chart would reveal a "Cutting Speed" in "Surface Feet per Minute". That number would be placed in a formula along with the diameter of the tool. This would give the RPM "recommended" for this specific situation. The feed would be determined by the pitch of the tap (1 divided by the number of threads per inch). For lathes, feed rate is usually expressed in inches per revolution. For every 1 revolution of the spindle the tool would advance the inches expressed in the feed rate. For a 1/4-20 tap, the pitch is 1 inch divided by 20 threads per inch which is 0.050 inches per thread, or 0.050 inches for each time the spindle rotates. This is a feed rate that would usually be expressed in G-code as F0.05.
    There are formulas, wizards, calculators, and programs that will do most of the calculations for you if you know what information to input.
    Well, the "best" thing to do is to go to school and learn. But I am sure you are not going to do that. So, you have to figure out a way to take short cuts. Have you read the Machinery Handbook? Do you even have a copy? Which books do you have for machining and CNC? Have you read them? Have you searched for online videos that demonstrate these different techniques and watched them? Does your software support tapping operations? Have you asked the software maker?
    A new Tapmatic tapping head will run you in the $500 to $900 range.
    A new tension compression tap holder will run from $50 to over $200.
    Which one has Tormach advised to use with the machine you intend to order?
    How the toolpath is generated is specific to the machine. You have not specified a machine. You hinted that it would be a mill. On a mill for a 1/4-20 tap, it might be as simple as:
    T01 M6
    M3 S500
    G0 G54 X0. Y0.
    G0 Z0.3
    G1 Z-0.75 F24.99
    M5
    M4 S500
    G1 Z0.3 F25.
    Or, the mill might have an option to use a G84 tapping cycle.
    Dec 2007
    School is not an option for me I wish it was. I work rotating shifts in job number 1 and job number 2 is running this business I need the machinery for. Rotating shifts nights to days and differing days off make a school schedule impossible. I have read several text books on machining manual machine work but I am self taught I have learned what I know from reading books and internet forums like this one. I do not have any books on CNC. What I have done was read through the tutorials on the software I have and learned to draw in cad and make toolpaths for my CNC router. The system I use now does not use Gcode but as I have learned to run the router I am sure I will learn to run the mill. I do not believe the software I have now supports tapping. Your explanation has helped me to understand that.
    I have talked with Tormach a couple times on the phone trying to figure out just what I need to order. They have not advised me on a tapping head. I have just started really getting serious about this and I am trying to figure out what to order. I am looking at the PCNC 1100 I have been playing with the options list and on the deluxe package I noticed it listed a tapping head. Sorry for some of my dumb questions but I am picking up some knowledge by asking these questions.
    May 2004
    Questions themselves are not dumb. What is important is that you use the information to make improvements.
    To change from an apprentice status machinist to a journeyman machinist it is recommended to take 576 hours of classroom training and over 8000 hours of on-the-job training (about 4 years). If you neglect the classroom training and only rely on the on-the-job training, that number of hours increases to 10304 (about 5 years). And remember, this is 4-5 years of serious, dedicated study and work. Doing it part time will take much longer.
    Jun 2006
    Regards,
    Ray L.
    If Tormach's tapping head is like the Procunier design, there is a clutch inside the head that allows the tap to "slip" if the spindle down speed is too slow for the tap. At least that's how I understand it. You stop down speed alltogether with the spindle rotating and the tap will not rotate at all. On Z reverse the gear train inside the head spins the tap at 2x spindle speed (or thereabouts). That system works a treat and I've used it to thread a bunch of 0-80 and 4-40 through holes in aluminum without one failure.
    I've got a Procunier 1E, which goes up to 5/16" or so, but have not yet modified it for my Tormach. When it gets done, I'll probably copy the approach that Don here developed for his. In the mean time, I'm waiting for delivery of one of Tormach's compression/tension heads and will try that out.
    Mike
    Registered Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    The Tormach does not have a servo controlled spindle and therefore the spindle cannot quickly stop and or reverse. This means that for blind holes tapping with a tension-compression type head will have to be done at slower speeds to allow for the spindle to stop and reverse. The advantage of a reversing type tapping head with the Tormach is that tapping blind holes can be done at high speed. My Procunier tapping head has a cushioned double-cone clutch that allows the tap to disengage within 1/3 revolution. That is perfect for tapping blind holes at high speed. With the Procunier I feed at 100%, no dwell, and retract at twice the downfeed. So with my 3 digit Tormach I am only limited by the maximum feed rate for retraction which is 65 IPM.
    Don
  • Page 1 of 5 1234 ... LastLast
    1. Procunier tension compression tapping head
      By MFchief in forum Tormach Personal CNC Mill
      Last Post: 09-06-2011, 09:58 PM
    2. Tension/Compression vs. Reversing tapping head
      By apeman88 in forum Tormach Personal CNC Mill
      Last Post: 07-29-2011, 07:30 AM
    3. Reversing Tapping head vs Tension/Compression tapping Head
      Last Post: 01-25-2011, 09:39 AM
    4. Tension & Compression tapping
      By cnc steve in forum General Metalwork Discussion
      Last Post: 04-04-2009, 06:10 AM
    5. Tension/compression tap holders
      By Caprirs in forum General Metalwork Discussion
      Last Post: 04-05-2007, 08:59 AM
