Results 1 to 7 of 7
Thread: Spindle speed slows down
    Registered carlboe's Avatar
    Mar 2008
    Hi
    I have Tormach 1100 and it looses spindle speed. Here is the problem I have been running for about a hour and it will drop the spindle speed 200 rpm. the feed rate is 30 and the depth of cut .020 3/8 end mill spindle speed is 1200. I have not been running a hour strait 3or4 minutes between parts.
    Thanks for the help
    carlboe
    Sep 2008
    Is the spindle drive belt tight?
    How do you know how many RPMs it is dropping? Have you put a tachometer on it?
    Mar 2008
    Yes I put a tachometer on it and belt is not that tight.
    Carlboe
    Jun 2006
    Stavanger, Norway
    Do you have the latest frequency converter (with LCD panel), if so have you looked to see if there is any corresponding change in frequency output. Apart for motor slippage due to load I thought that the motor speed should follow the frequency.
    But what do I know.
    Phil
    Quote Originally Posted by carlboe View Post
    Hi
    Thanks for the help
    carlboe
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    I wonder if it's related to motor temperature.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Nov 2006
    I have also experienced a similar spindle speed problem, and in fact still do now and then. Tormach suggested that I wiggle all portions of the parallel port cable path going from the control computer all the way up to the machine control pcb. I found that wiggling just the parallel port ribbon cable connector at the machine control board seems to fix my issues, until they crop up again, days, weeks or months later. I need to get a replacement ribbon cable, as I'm fairly confident that is in fact the cause of my spindle-speed errors, which sound much like what you are experiencing.
    Wog
    Wog is offline
    Oct 2008
    I had moved my Tormach about 1600 miles via the back of a Penske truck a couple of years ago. Ended up with several problems/glitches including speed control. Greg at Tormach suggested the same as Bobeson. I pulled and re-installed all the ribbon cables and haven't had a problem since. Hopefully, Carlboe, it's "just a loose wire".
    1. Spindle speed via dsp??
      By 7of9 in forum Chinese Machines
      Last Post: 12-21-2012, 03:41 AM
    2. Problem- mach3 spindle dro not working, spindle speed changing while jogging and running code
      By jasminder in forum Mach Software (ArtSoft software)
      Last Post: 02-23-2011, 01:12 AM
    3. Spindle Speed
      By mikemill in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-04-2008, 11:09 AM
    4. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
      By peter.blais in forum Bridgeport and Hardinge Mills
      Last Post: 08-08-2006, 04:29 AM
    5. Mastercam 8 slows down my computer
      By Christian in forum Mastercam
      Last Post: 05-12-2004, 07:58 PM
