Results 1 to 5 of 5
Thread: Slots and Holes in .040 Aluminum Sheet
    Jul 2011
    I'm looking for some ideas on how to mill slots and holes in .040 aluminum sheet. My problem is, I need something to "back" the aluminum while it is being milled. I intend to cut dry. Plywood came to mind, but it's kind of hard on the end mill, as there is significant heat in cutting the wood. HDPE was a thought too, but I'm thinking it might melt, and create a gummy blob of plastic and chips.
    Anyone have any success stories?
    Thanks,
    John
    Wog
    Wog is offline
    Oct 2008
    Static-dissipative UHMW allows tape adhesion, can be threaded, and mills like butter. I've never had a problem with it melting using sharp end mills/drills.
    Registered Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    Have you considered chemical milling?
    Don
    Jun 2006
    Stavanger, Norway
    MDF has worked for me as a backing material when milllng 1.5mm brass plate.
    Phil
    Mar 2010
    Whats wrong with Aluminum backing? I now keep scrape aluminum just for that reason. I am also setting up a vacuum system to cut about .04 SS myself. So will have aluminum backing for it as well.
    1. Replies: 0
      Last Post: 09-09-2010, 02:28 AM
    2. Just IN- Need help chamfering holes in sst sheet
      By Vretsam in forum General Business Practices and Pricing
      Last Post: 11-17-2009, 06:58 PM
    3. Need A Quote- Aluminum plate with slots
      By ranagent in forum Employment Opportunity
      Last Post: 08-28-2008, 05:52 PM
    4. How to tap 1000 2-56 holes in Aluminum?
      By Driftwood in forum General Metalwork Discussion
      Last Post: 08-21-2006, 02:41 PM
    5. Need help with T-Slots - Boring holes
      By samualt in forum DIY CNC Router Table Machines
      Last Post: 04-10-2004, 11:39 PM
