Results 1 to 12 of 12
Thread: 3 Phase?
    Dec 2010
    3 Phase?
    Am I going to need to buy a converter? Was figuring on trying to avoid it, but if I end up needing one with the Tormach, I may be revising what I'm thinking about in terms of machinery...
    Registered 300sniper's Avatar
    Jul 2007
    all tormach machines i am aware of run off of single phase power.
    Jul 2005
    The new stepper motors are three phase DC, not the AC input power source. The mill's internal electronics rectify the current as appropriate.
    Jun 2006
    Stavanger, Norway
    Read the documentation.
    Phil
    Dec 2003
    Maybe the confusion comes from the indication it has a 3phase spindle motor being unaware that the invertor can be 1ph fed?
    Jul 2005
    I'm not sure where the confusion is coming from, but all Tormach mills run on household current, 110 or 220 AC - nothing special.
    Dec 2003
    Quote Originally Posted by byellin View Post
    The area of confusion that may occur as I referred to previously is part of the manual quoted below, to the uninitiated it may seem that 3ph is required.
    The spindle is driven by a robust 1.5HP 3-phase induction motor powered by state-of-the art sensorless vector variable frequency drive technology from Emerson Control Techniques™
    Jun 2006
    Stavanger, Norway
    Tormach has one of the most comprehensively documented machine tool websites on the net. Seek and Ye shall find. So not surprisingly you can find the necessary information on the mill data sheet, under the section titled "specification" quote:
    "Power Power Requirements: 200-250 VAC 50/60 Hz single phase
    (primary). 20A breaker recommended
    115 VAC 50/60Hz (secondary)"
    Phil
    PS: Not only has the OP not done his home-work, he hasn't even open his books and pretended that he's done his home-work. The excuse that the dog ate it wont wash either.
    Dec 2010
    Philbur, when I see one thing on the web site, which I've pretty much combed over, since I'm planning on spending over $15K, and I see another thing in another spot, and something else in another, and they JUST CHANGED THE SPECS ON THE MACHINE, I sort of wonder if maybe they still haven't worked all the bugs out of their documentation...
    Heck, I've seen stuff that has three-phase motors, and they have some handy-dandy static converter bolted onto the side... I see that as somewhat less than optimal if you have the real thing available.
    Right now I'm sitting about 15 yards from a monster rotary converter... Which is sitting right next to a Milltronics Partner X which, paradoxically, runs on "regular" 220... Go figure... Our three-phase wall is for the Bridgeports, the Jets, The Shizoukas, and a couple of monster drill presses and surface grinders. Heck, we've got one surface grinder in storage that's wired for 440 - which is probably why it's in storage...
    Jun 2006
    Stavanger, Norway
    So the dog did eat it then.
    Phil
    Quote Originally Posted by bogiestl View Post
    Registered Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    This may help:
    Stepper motor - Wikipedia, the free encyclopedia
    "Higher-phase count stepper motorsMulti-phase stepper motors with many phases tend to have much lower levels of vibration,[2] although the cost of manufacture is higher. These motors tend to be called 'hybrid' and have more expensive machined parts, but also higher quality bearings. Though they are more expensive, they do have a higher power density and with the appropriate drive electronics are actually better suited to the application[citation needed], however price is always an important factor. Computer printers may use hybrid designs."
    and
    Variable-frequency drive - Wikipedia, the free encyclopedia
    Dec 2010
    Thanks... Hey, I'm a designer, not an electrical engineer... I plug stuff into the wall. It works. I'm happy. If it doesn't work, there's the telephone...
    1. Need Help!- Legacy Vexta 5 Phase Drive with new 5 phase motor
      By powerfade in forum Stepper Motors and Drives
      Last Post: 07-19-2011, 10:22 PM
    2. Change a motor from 415v 3 phase to 220v 3 phase
      By Me2 in forum Phase Converters and VFD
      Last Post: 06-02-2010, 05:29 PM
    3. Convert three phase transformer to single phase?
      By jimjovan in forum General Electronics Discussion
      Last Post: 12-10-2009, 03:17 PM
    4. Replies: 12
      Last Post: 10-12-2009, 10:53 PM
    5. Can I convert single phase motor to three phase?
      By Jim Estes in forum Phase Converters and VFD
      Last Post: 01-24-2009, 03:41 AM
