Page 1 of 3 123 LastLast
Results 1 to 12 of 27
Thread: Tapered Holes
    Mar 2010
    Tapered Holes
    What is the best way to machine an ID hole that has a slight taper? It needs to be as smooth as possible as the tumbler media will probably not be able to finish it like I want.
    Material is 7075 AL
    Hole size is .485 tapered to .378
    Aug 2005
    What is the distance from the large end to the small end or how thick is the
    material or how deep is the hole?
    Ernie
    Mar 2010
    Forgot those Ernie...
    Hole depth is .5 .. wall thickness will be .075 at the .485 dia.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    The best way: Chuck it up on a lathe, bore it, then use a toolpost grinder to finish it.
    The best way on a Tormach: You could grind the taper as above if you have a fourth axis. You will need to set the axis at the same angle as the taper.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Aug 2005
    Am I correct in assuming then, that we are talking about a cylinder that is .635
    in diameter and .500 long with the tapered hole in it?
    Ernie
    Mar 2010
    Quote Originally Posted by ErnieD View Post
    Ernie
    Pretty much.....yes
    Mar 2010
    Quote Originally Posted by TXFred View Post
    Frederic
    The tapered hole is the ID, not the OD.
    Mar 2010
    Ernie
    But let me add, it is a boss on the end of a 2.5IN OD Round. So the wall thickness will not be much of an issue as I can always remove that after the hole is tapered...
    Jul 2007
    Maybe a setup like this would work?
    http://www.cnczone.com/forums/tormac...cal_lathe.html
    Tormach PCNC1100, Mach 3 R3.043.037, MastercamX5 level 3.
    Mar 2010
    Quote Originally Posted by btu44 View Post
    I am contemplating doing that for other parts, but I do have a lathe. But I don't remember anything in that post on doing a tapped hole, just thru holes.
    Aug 2009
    Austin, TX
    Quote Originally Posted by Magnum164 View Post
    That's what I was picturing. "Hole" generally implies that it's got an inner diameter.
    You can grind an inner diameter, given a small enough stone. In this case, you could mount a Dremel tool in the toolpost to do the grinding.
    Frederic
    Wog
    Wog is online now
    Oct 2008
    I would use the forth axis or even a basic rotary table mounted at a 6.1 degree incline. Would a 3/8" (max. diameter) 4 flute end mill leave too rough of a finish?
  • Page 1 of 3 123 LastLast
    1. Need Help!- Tapered screw
      By peter737 in forum Solidworks
      Last Post: 05-20-2011, 02:33 PM
    2. Tapered Helix, Is it Possible?
      By bgmnn in forum HURCO
      Last Post: 03-11-2011, 10:55 PM
    3. Tapered holes?
      By zaebis in forum General Metal Working Machines
      Last Post: 08-21-2009, 08:06 AM
    4. Tapered ID Threads
      By mkimco in forum Cincinnati CNC
      Last Post: 03-19-2009, 03:54 PM
    5. Tapered gib
      By chevdrgtrk in forum General Metal Working Machines
      Last Post: 11-28-2006, 02:56 AM
