Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 27
Thread: Tapered Holes
  1. #13
    Jul 2004
    Ive machined a ball joint taper to accept a ball joint.. about what you are talking about with a ball mill and a small scallop. Probably .0001. Turned out great....
    You'll need a 3D CAM program to do it though.(forget if you have one)
    David
  2. #14
    Aug 2010
    If my math is right, you have a 6.1 degree taper on a side. If that taper doesn't have to be exact, could you just use a conical end mill with that taper and either plunge it or circle mill with a slightly smaller mill diameter?
  3. #15
    Mar 2010
    Quote Originally Posted by David Bord View Post
    David
    Yes, I have Alibre and Rhino. Would be interested in how you did that.
  4. #16
    Mar 2010
    Quote Originally Posted by Tbkahuna View Post
    Close, I have not drawn it up yet, but I will trust your math.
    The taper does not have to be extremely accurate. Its a press fit on a shaft held in with a through bolt. The taper is only so you are not trying to press it on the shaft the full length of contact. (just needs to be pretty until installed)
  • #17
    Mar 2010
    Quote Originally Posted by TXFred View Post
    That's what I was picturing. "Hole" generally implies that it's got an inner diameter.
    You can grind an inner diameter, given a small enough stone. In this case, you could mount a Dremel tool in the toolpost to do the grinding.
    Frederic
    I am not that accurate with a lathe yet. once the prototype is done I will need 50 to start then who knows how many. So I was hoping there was a nice way to do this on the Tormach... It's so slight an angle there has to be an easy repeatable way to do it.
  • #18
    Aug 2010
    You can get conical end mills with 1 degree to 15 degrees (or more) of taper.
    That would be an easy way to do it.
  • #19
    Wog
    Wog is offline
    Oct 2008
    Agree.
    At 50+ pieces, that's what I'd go with.
  • #20
    Jun 2006
    If the holes need a really good finish you might consider a Tree Boring Head, which will bore a tapered hole. They may no longer be available new but there seems to be a fairly good used market and used heads are often in good condition since they don't get used much.
    Mike
  • #21
    Mar 2010
    Thanks Mike, I found some and they are rather expensive.
    I am going to rethink my design some. I may try and do some practice cuts on my lathe and see how hard it is to setup and cut the angle as some have suggested.
  • #22
    Registered 300sniper's Avatar
    Jul 2007
    is a tapered reamer too simple?
  • #23
    Mar 2010
    I have not found a tapered reamer except for hand held versions.
    But I did find a tapered end mill that might work. Its 7 degree, but will most likely be ok.
  • #24
    Jul 2007
    i have my rifle chamber reamers ground to my specs by pacific tool and gauge: Welcome To Pacific Tool and Gauge Inc. -- Reamers, Gauges, Bushings, and more.. i bet they could grind a reamer exactly as you need if you run out of options.
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Need Help!- Tapered screw
      By peter737 in forum Solidworks
      Last Post: 05-20-2011, 02:33 PM
    2. Tapered Helix, Is it Possible?
      By bgmnn in forum HURCO
      Last Post: 03-11-2011, 10:55 PM
    3. Tapered holes?
      By zaebis in forum General Metal Working Machines
      Last Post: 08-21-2009, 08:06 AM
    4. Tapered ID Threads
      By mkimco in forum Cincinnati CNC
      Last Post: 03-19-2009, 03:54 PM
    5. Tapered gib
      By chevdrgtrk in forum General Metal Working Machines
      Last Post: 11-28-2006, 02:56 AM
