CHEATER!
You have a Power draw bar for the 770.. Not fair.. I am looking into the plans now! That looks sweet and I can use one.
I have a bad back and to top it all I am short, so reaching to tighten the draw bar is always rough for me.
Hello Everyone,
I have own a 770 for over six months now and I wrote a short review about it on my website. I think it can be of interest to anyone who is interested in getting the same machine. Here is a link:
TormachTOC
I will try to keep the site updated in the future as well. Let me know if you have any comment!
Christian
CHEATER!
Nice web site and review
The power draw bar is cool too.
To late now but you can buy a duplex outlet that the Tormach male plug will fit into at just about any home store, I got one at Home Depot. It only cost 3 or 4 dollars if I recall. I attached a picture.
Thanks for the review, I always liked the way you set up your shop.
That is a 20-amp outlet, Gerry, so make sure that it is fed by a 20A breaker and the wiring run will also support 20A loads. Equipment that needs 20A service has the special plug so it can't be plugged into a 15A circuit and overload it.
Not saying that you did, but someone who wires that outlet to a 15A circuit breaker is violating electrical code and their homeowner's insurance will also be invalid if a fire starts because of overheated wiring.
Randy
Be sure to check your local codes. If I understand correctly what I was told, you can't put that 30amp plate on wires/boxes rated for 15-20amp. That's why I elected to change the Tormach plug as I did not think it would need 30amps unless I was really loading up the motor which I have no need to do. So far it has been fine. No blown fuses to date. And just for clarification my wiring will handle the 30amps, I just have an old fuse box that we try and keep at 15 amps.
Christian,
Would you mind posting some pics of the PDA and it's mounting? Just curious how that is mounted as opposed to the plans. Which hopefully I will have in a day or two.
Thanks for the heads up fellas, it is a dedicated 20 amp circuit for the mill with a 20 amp breaker in the box and 12-2 wire (I think that all is req'ed in my area is 14-2 on a 20 amp run but I ran 12-2).
Here is a link to the outlet I bought, it's rated for 20 amps, not 30
Leviton 20 amp Duplex Outlet - R52-05352-0WS at The Home Depot
But good info for someone trying to wire their 770?
Thank you Gerry for your suggestion, I wish I had known. I remember reading in the manual for the 770 that the plug was a standard american 110v before buying. I guess they should update that at some point.
Magnum, I will take a picture tomorrow and post it here but I may be able to find the dxf file, somewhere. I do have the g-code producing the plate, that could work for you. I'll get back to you later.
Christian
Nice review, thanks for writing it up. One day, if I go further with some ideas I may be looking at a 770 or 1100 but for now I just have to look at other people's and drool. The only real drawback I see for me on the 770 is the small X axis travel. I like the 19" on my PM-25 and wish they would get the 770 at least 15 or 16. Otherwise it's a kick butt little machine with a 10K spindle which would be another world for me with small tools.
CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
