Results 1 to 8 of 8
Thread: Mastercam and Tormach
    Dec 2007
    united states
    Is there anyone running mastercam, and if so are you using the generic fanuc post processor. if so which edits do you have to do. Thanks All
    Jan 2007
    I'm running Mastercam X2 MR1 using a post I picked up somewhere along the lines.
    I'm pretty sure it was just the MPMaster.pst that was around a while back, had to update it to work with x2
    More or less works fine
    Mooser
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    I'm able to generate good Gcode for the Tormach using a Haas 4 axis post.
    The only thing I had to tweak was that Haas uses G154 PXX for extended work offsets, and Mach uses a different number.
    Try some of the default Haas posts that come with MasterCAM and see if any of them do the job.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Registered Gerry Sweetland's Avatar
    Feb 2008
    not sure which machine you have but there is this post for an 1100 in the support documents page at Tormach.
    It mentions using the Fanuc post too
    " 5/22/07 - Mach3.pst
    Adds the PCNC 1100 to MasterCAM post list.
    Also, some customers have said that the mpfan.pst file included in MasterCAM has worked well for them.
    Here is the link...
    http://www.tormach.com/document_library/Mach3.pst
    Jun 2007
    What versioin of mastercam are you using? I've done the mpmaster post for the Tormach. I think it's still on the yahoo tormach group in the files section.
    I use Mastercam X5 on my Tormach.Fully configured, 4th axis, tapping head, ...
    Dec 2007
    united states
    Hey sorry guys just checked back in on my thread. Im running x3 mill level 2, Im using the generic fanuc post and its the A0 code that has to be edited out. Programmed my first part, it was a rectangle LOL did okay. my speeds and feeds were off a little got alot more practice to do.
    Jul 2007
    I've been using Freddy's post for years and have not had any problems. It adds a M998 tool change position code before a tool change. Also in the Drill toolpaths, there is a TAP POSITION selection. While in Single Block mode, you can move over programmed holes with a tap center for hand tapping. I use the often.
    If you want to get rid of the the A0 code...goto Settings > Machine Definition Manager > Machine Configuration. Uncheck VMC A Axis & chuck. That should do it.
    Tormach PCNC1100, Mach 3 R3.043.037, MastercamX5 level 3.
    Dec 2007
    united states
    Thanks btu, sat in alot of mastercam classes and they never went over that little change.
    1. MPG for a Tormach
      By hall6ppc in forum Tormach Personal CNC Mill
      Last Post: 06-30-2011, 07:05 PM
    2. Post Processor for Mastercam and Tormach
      By mattford1 in forum Tormach Personal CNC Mill
      Last Post: 08-23-2010, 02:19 PM
    3. Tormach vs X3 CNC
      By daclearwater in forum Benchtop Machines
      Last Post: 07-02-2008, 10:09 PM
    4. Tormach Tapping and Mastercam
      Last Post: 03-17-2008, 11:10 AM
    5. Help with my new Tormach
      By kokopelli in forum Tormach Personal CNC Mill
      Last Post: 07-15-2007, 12:55 PM
