Results 1 to 2 of 2
Thread: How to configure Mach3 on a Tormach.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    I've got a new 1100 Series II, with the Tormach computer for it.
    I'd like to make some settings changes. I want to enable soft limits, and change the SafeZ setting. Right now, if I use the Run From Here feature, the mill goes to Z=0 and then attempts to rapid move in X and Y!
    How do I get access to all the hidden menus in Tormach's Mach3 setup?
    Sincerely,
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Jul 2007
    Tormach has a utility for tweaking some Mach parameters. Beyond that, Tormach will provide you with an unlocked configuration file though you have to sign a waiver to get it. That may also void your warranty.
    bob
  1. Need Help!- Four axis Controller Mach3 Configure+Wiring
    By winattitude in forum Controller & Computer Solutions
    Last Post: 08-27-2009, 03:12 AM
  2. Newbie- How configure serial port on mach3
    By arthur&co in forum Mach Software (ArtSoft software)
    Last Post: 04-25-2009, 11:21 AM
  3. How to Configure Galil I/0 with MACH3
    By manoj2s in forum Mach Software (ArtSoft software)
    Last Post: 06-28-2008, 01:13 AM
  4. How to configure JGRO with mach3 or TurboCNC
    By Ragnarok in forum JGRO Router Table Design
    Last Post: 09-03-2007, 02:26 AM
  5. Mach3 configure question?
    By dmgdesigns in forum Mach Mill
    Last Post: 11-14-2005, 02:57 PM
